I seem to be halfway between solutions, and was wondering if there was a fix that might help.
The SMA solar integration is lacking bluetooth connectivity, while the SBFspot/PVoutput combo don’t really suit my hardware setup.
Is it possible to add bluetooth connection option to SMA Solar as a feature request?
Is there an easy way to install SBFspot into home assistant on a supervised install?
(I sort of feel like this could be done with a python wrapper and then via installed HACs, although that will take me months to figure out)
So this is how I end up at SMA Solar and wondering how possible it is to add bluetooth support.
[SMA Solar - Home Assistant](https://SMA Solar Integration)
[Installation Linux SQLite · SBFspot/SBFspot Wiki · GitHub](https://SBFspot + PVoutput upload)
As a backstory I use SBFspot on my SMA inverter currently and upload the data to PVoutput. However to do this SBFspot is installed on my desktop PC, which won’t upload if it’s asleep. I also already pull the data into HA via MQTT. The problem is in data consistency if my PC is asleep. I would ultimately like my HA server to access the data directly, which doesn’t currently seem possible short of moving to a docker type install.
Thanks.
