SMA Speedwire Integration
Is there a way to get this on a VM with HAOS working?
Of course.
You need the Home Assistant integration found at
It relies on the Python library which should be automatically installed, but it can be found at
Thanks, I created the folder manually and copied the files into this folder.
Now I have a SunnyBoy Inverter Speedwire listed in my home assistant.
Will see tomorrow if I get any data.
I managed to install this, and I see measurements comming through. But when I try to add it to the energy dashboard I don’t see the values.
It works for me. How have you added your sensors to the energy dashboard?
Would it be possible to install this via HACS?
