SMA SUNNY TRIPOWER 10.0 SE Energy Dashboard
i want to setup the energy dashboard for my SUNNY TRIPOWER 10.0 SE but i fail. I have already configured the device in Home Assistant and i see a lot of needfull values:
In the configuration of the energy dashboard i see five values. Every combination i tried gives me rubbish data in the energy dashboard. So any advice would help :wink: Which value belongs to which field in the energy dashboard?
  • battery_charge_total
  • battery_discharge_total
  • metering_total_absorbed
  • metering_total_yield
  • pv_gen_meter
  • total_yield
best regards,
Snooops
is your SMA HomeManager connected to your Tripower? If not you should connect it as the HomeManager cannot be read by HA (as far as I know from my system).
from the Homemanager you get more values. then you can configure EnergyDashboard like these (sorry for the german keywords, not sure if the google translation would be correct)
grid_total_absorbed ← netzbezug?
grid_total_yield ← netzeinspeisung
pv_gen_meter ← PVProduction
battery should be clear
kind regards
Marc
Thank you for your reply - and sorry for my late answer.
I guess the Tripower is connect with SMA HomeManager, because the sunny dashboard app shows valid data. How could it be if those two are not connected properly?
i don’t have the fields you have… hmm weird.
did you find out any solution for this? i am trying to get a SMA Tripower 6.0 SE into the dashboard… The tripower is directly connected to a sma sunny home manger 2.0.
The webinterface of the tripower shows all values correctly.
I got the integration SMA Solar set up and running. but i didnt find the right sensors or they are not accepted in energy dashboard.
Maybe i am just missing a thing here?
