SMA - Unfortunately, I'm missing the entity ID for self-consumption
I set up my PV system from SMA. Unfortunately, I’m missing the entity ID for self-consumption. Does it even exist or can I possibly calculate the value from 2 different entity IDs?
Did you get the SMA power meter installed as well, or only the inverter?
Hi. I have add this Add On.
SMA Solar - Home Assistant (home-assistant.io)
I have an Tripower 10.0 and an Sunny Home Manager 2.0
So that’s a “no” then.
You have no method of determining how much your house is consuming. The inverter only measures how much is being produced.
Hi Tom.
I can calculate the self-consumption between 2 values. I have the generation and the feed too. The difference from this would be self-consumption. Unfortunately, I am not familiar with HA yet so well to create such a field.
Search for “template sensor”.
Sunny Home Manager 2.0 is a power meter…
