Small bash code to automate a git pull and restart the docker
This might, or might not be of use to anyone else, however, I wrote a very basic bash script to git pull from my
repo and then restart the home-assistant docker.
Hopefully, it may help someone :slight_smile:
#!/bin/sh
git fetch
UPSTREAM=${1:-'@{u}'}
LOCAL=$(git rev-parse @)
REMOTE=$(git rev-parse "$UPSTREAM")
BASE=$(git merge-base @ "$UPSTREAM")
if [ $LOCAL = $REMOTE ]; then
   echo "Up-to-date"
elif [ $LOCAL = $BASE ]; then
   git pull && docker restart home-assistant
elif [ $REMOTE = $BASE ]; then
   echo "Need to push"
else
   echo "Diverged"
fi
Run this as a cron job are you’ve got a self-updating home assistant entity. Perfect for those lunchtime code amends.
Jack
Thanks that looks really interesting. :+1:
Would you mind however tagging it as “share your projects”?
wasn’t quite sure where it lived - now edited
