Hi, I’m looking for a battery powered Smart button with one, or better more, inputs. Can be DIY.
Some use cases: doorbell, light switch, door/window sensor, cabinet drawer/door sensor, detect gas meter counter with a reed Relais and more.
I could use an ESP32 or similar, but I don’t necessarily want WLAN because I don’t want to overwhelm my router. And I’m not sure if the battery life is good or not.
It should be small enough to fit behind a regular (German) wall switch (size of Shelly devices).
Ideally it can run with a 3.6V Lithium batterie (AA size) and I can read the battery level in Home Assistant to create an alarm for low battery.
Summary: I need something like the Shelly Plus i4, but cheaper, battery powered and not necessarily with WLAN.
Agreed, but you mentioned not wifi
I tried a sonoff zigbee one (which would also need a receiver) but this is 2x as expensive and for my simplistic use…rather pay half…but this is personal decision of course. The zigbee one has single/double click
I think, Bluetooth is not a good solution for me (and for Smart Home in general). And I don’t want to span another wireless network in my home. I think, WLAN, Zigbee and DECT are enough.
I ordered some ESP8266 devices to play around. I try to run them with 3V button cells. Maybe it works for me.
