Small temperature logging setup
Hi all,
I would like to monitor temperature and humidity in three rooms where one is quite large so I was considering two sensors for this room. Max budget for the moment is 150€.
Right now I’m considerung to go with the Shelly Plus H&T.
To avoid adding a extra base station I would prefer to use Wifi.
I’m expecting that HASS will do all the monitoring out of the box.
Is the chosen hardware okay or what you propose something else?
The goal is to simply monitor the temperature over the winter.
