Smanos w100 alarm panel
I’ve been using a closed source alarm panel from a chinese oem called smanos.
Looks like it is just a rebranded chuango for the western markets.
The panel is w100 and provides no api.
Came upon a security cve about this panel that it makes it vulnerable from an attacker on the same network.
I managed making use of that cve to get the payload for arming,disarming and setting to home mode l.
These are enough data to automate the panel with a bash script using netcat.
Its a 2018 panel so if anyone left over with it this might be helpfull.
You’ll need your device id.
Save CVE-2019-13361/poc.py at 75712ea4d6308d2c2d5bc3693b27170da6869cc9 · lodi-g/CVE-2019-13361 · GitHub as a .py file
usage: a [-h] [-p PORT]
ip wifi_ssid wifi_password
e.g. script.py 192.168.1.1 mywifi 123456
It will return:
set_wifi: receiving:    b'CGWPSC030000deviceid**\r'
set_wifi: device_id:    b'xxxxxx**'
disarm: sending:        b'CGWPCS53xxxxxxxxxx**2'
disarm: receiving:      b'CGWPSC53xxxxxxxxxxxxx**1001\r'
Your payload is what the device returned as "disarm: sending: "
The number after ** is the Mode: 0/1/2 ; Disarm/Arm/home
Knowing the payload you can use it to any script to change the panels mode
I created 3 scripts under config/shell_scripts/
w100_arm.py
w100_disarm.py
w100_ome.py
And made them executable chmod +x
They are identical only the last number of the payload changes.
#!/bin/bash
ip="192.168.1.1"
ssid="mywifi"
pswd="123456"
port=60003
payload="CGWPCS53xxxxxxxxxxxxxxc**0"
# Function to send payload and exit after 10 second
send_payload() {
    { echo -n "$payload" | nc -w 10 "$ip" "$port"; } > /dev/null 2>&1 &
    sleep 1
    kill %1
# Main
send_payload
And added to the configuration.yaml
shell_command:
  w100_home: /config/shell_scripts/w100_home.sh
  w100_disarm: /config/shell_scripts/w100_disarm.sh
  w100_arm: /config/shell_scripts/w100_arm.sh
Restart home assistant
You can use the scripts as actions in automation.
My example with voice assistant
alias: W100 arm
description: ""
  - platform: conversation
    command:
      - alarm on
      - Turn on alarm
      - Turn-on alarm
      - Turnon alarm
      - Turn on the alarm
condition: []
  - service: shell_command.w100_arm
    data: {}
mode: single
**afterthoughts:
  1. I’m totally new with home assistant and not an advanced user at all. Scripts and integration my not be polished .
  2. Thanks to @tetele and @Tinkerer on the discord server that helped me out
#todo:
Decompiled the android app.
Uploaded the relative java class containg the payload info W100 - Pastebin.com
It may contain addidtional info for further use cases.
Hi @ippocratis ! Thank you for this - this has been tremendously helpful.
Not sure if you’re still using your W100 panel, but I’ve also been working on reverse-engineering it especially as the notifications server has gone offline in the past weeks.
If you’d like to connect, let me know. Happy to share where I’m at.
Hey @pjft if you have any insights regarding reverse engineering this panel I’d love to hear it
Looks like the panel push plain tcp messages on 60003
Created a python listener
#!/usr/bin/env python3
import socket
def listen_notifications(s):
    while True:
        try:
            data = s.recv(1024)
            if not data:
                break
            print(f"Notification received: {data}")
        except Exception as e:
            print("Error receiving:", e)
            break
def main():
    ip = "192.168.1.100"   # replace with your panel IP
    port = 60003           # default port
    with socket.socket(socket.AF_INET, socket.SOCK_STREAM) as s:
        s.connect((ip, port))
        print("Connected, waiting for notifications...")
if __name__ == '__main__':
    main()
and triggered a magnetic contact the script printed
 Notification received: b'CGWPSC01010112345A6**
020202202508231910510\r'
So I have
  • CGWPSC01 → Protocol header (type of message, probably “event/notification”).
  • 0101 → Could be a zone number / device number.
  • 12345A6 → Very likely my device ID (matches what I extracted in my Wi-Fi setup step).
  • ** → Mode / event separator (like in disarm/arm payloads).
  • 020202 → This is almost certainly the event code (magnetic contact open/triggered).
  • 20250823191051 → That looks like a timestamp:
    • 2025 → year
    • 08 → month
    • 23 → day
    • 19:10:51 → time (exactly when you triggered it).
  • 0\r → End of packet marker.
From here I tried simple ntfy notifications extending the tcp listener script with ntfy and human readable text making sure the ntfy topic mach in the script and in the iOS android app
import socket
import requests
def send_ntfy(message, topic="myalarm"):
    url = f"https://ntfy.sh/{topic}"
    try:
        r = requests.post(url, data=message.encode("utf-8"))
        print(f"Sent notification: {message} (status {r.status_code})")
        print("Error sending ntfy notification:", e)
def parse_notification(data):
    msg = data.decode(errors="ignore").strip()
    if msg.startswith("CGWPSC01"):
        device_id = msg[12:20]
        event_code = msg[22:28]   # e.g. 020202
        timestamp = msg[28:42]    # YYYYMMDDHHMMSS
        events = {
            "020202": "Magnetic contact triggered",
            "010101": "Panel armed",
            "000000": "Panel disarmed",
            # Add more as you learn the codes
        return f"{events.get(event_code, f'Unknown event ({event_code})')} at {timestamp}", msg
    return "Unparsed event", msg
    while True:
        try:
            data = s.recv(1024)
            if not data:
                break
            parsed, raw = parse_notification(data)
            print(f"Notification received: {raw}")
            print(f"Parsed: {parsed}")
            send_ntfy(parsed)
            break
def main():
    ip = "192.168.1.100"   # <-- replace with your panel IP
    port = 60003           # <-- default port
    main()
Triggered the same magnetic contact and boom I had a notification on my phone
From here I think adding home assistant buttons and notifications will be easy . I just have to find all my sensors device zone numbers wvwnt codes etc .
I just have to trigger each on and read the print out .
I’ll come up later updating this guide when I got some time and all is ready
@pjft I’ve put it all together in my blog since I can’t edit my initial message here
Have a look
Again if you have any more ideas or you have come to any additional findings please post them here
Hi man, thank you very much for this explanation, i found a way to get alarm status from Home Assistant, you can check it:
  w100_status: >
    python3 -c "import socket; s = socket.socket(socket.AF_INET, socket.SOCK_STREAM); s.settimeout(5); s.connect(('192.168.5.160', 60003)); s.sendall(b'CGWPCS540000<DEVICE_ID>27'); s.close()"
This will answer you:
"CGWPSC540000<DEVICE_ID>27010000001" = "disarmed"
"CGWPSC540000<DEVICE_ID>27210000001" = "home_armed"
"CGWPSC540000<DEVICE_ID>27110000001" = "armed"
And i also create a input select
input_select:
  smanos_mode:
    name: Estado Real Alarma
    options:
      - disarmed
      - armed
      - home_armed
So then i created a card with status:
type: horizontal-stack
cards:
  - type: custom:button-card
    entity: input_select.smanos_mode
    icon: mdi:shield-lock
    tap_action:
      action: call-service
      service: script.alarm_arm
    state:
      - value: armed
        styles:
          card:
            - background-color: "#27ae60"
            - color: white
          icon:
            - color: white
    styles:
      card:
        - background-color: var(--ha-card-background, var(--card-background-color, "#34495e"))
        - color: var(--primary-text-color)
        - border-radius: 12px
        - border: 1px solid var(--divider-color, rgba(0,0,0,0.1))
        - box-shadow: var(--ha-card-box-shadow, 0px 2px 4px rgba(0,0,0,0.1))
        - transition: all 0.3s ease
      icon:
        - width: 40px
      grid:
        - grid-template-areas: "\"i\" \"n\""
        - grid-template-rows: 1fr min-content
      name:
        - font-size: 14px
        - font-weight: bold
        - padding-bottom: 5px
    icon: mdi:shield-off
    tap_action:
      service: script.alarm_disarm
    state:
      - value: disarmed
        styles:
          card:
            - background-color: "#c54133"
            - color: white
          icon:
            - color: white
    styles:
      card:
      icon:
        - width: 40px
      grid:
      name:
        - font-size: 14px
        - font-weight: bold
    icon: mdi:car-side
    tap_action:
      service: script.alarm_home
    state:
      - value: home_armed
        styles:
          card:
            - background-color: "#0c93bf"
            - color: white
          icon:
            - color: white
    styles:
      card:
      icon:
        - width: 40px
      grid:
      name:
        - font-size: 14px
        - font-weight: bold
title: Alarma
and a button-card that reloads every time that app or browser loads
icon: mdi:refresh
aspect_ratio: 20/2
styles:
  card:
    - padding: 1%
custom_fields:
  ejecutor: |
      const ahora = Date.now();
      if (!window.lastRun || (ahora - window.lastRun) > 10000) {
        window.lastRun = ahora;
        hass.callService('script', 'alarm_status');
tap_action:
  service: script.alarm_status
I also edit the python to use appDaemon and to avoid requests libraries, and add the status changed like this:
                        if "CGWPSC530000<DEVICE_ID>**1001" in msg:
                            self.log("Confirmación de comando recibida. Ejecutando shell_command w100_status...")
                            self.call_service("script/alarm_status")
                        if "CGWPSC540000<DEVICE_ID>2701" in msg:
                            self.set_state("input_select.smanos_mode", state="disarmed")
                            self.log("Estado detectado: Desarmado")
                        if "CGWPSC540000<DEVICE_ID>2721" in msg:
                            self.set_state("input_select.smanos_mode", state="home_armed")
                            self.log("Estado detectado: Home Armed")
                        if "CGWPSC540000<DEVICE_ID>2711" in msg:
                            self.set_state("input_select.smanos_mode", state="armed")
                            self.log("Estado detectado: Armed")
Here is what is look now:
