yesterday my graphs based on the smappee integration (cloud) suddenly flatlined. Is seems that the integration can’t connect anymore to the cloud api. Any one else facing the same?
Logger: homeassistant.config_entries
Source: components/smappee/__init__.py:104
First occurred: 17:31:04 (1 occurrences)
Last logged: 17:31:04
Error setting up entry smappeeCloud for smappee
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 304, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/smappee/__init__.py", line 104, in async_setup_entry
await hass.async_add_executor_job(smappee.load_service_locations)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/local/lib/python3.9/site-packages/pysmappee/smappee.py", line 30, in load_service_locations
sl = SmappeeServiceLocation(service_location_id=service_location.get('serviceLocationId'),
File "/usr/local/lib/python3.9/site-packages/pysmappee/servicelocation.py", line 74, in __init__
self.load_configuration()
File "/usr/local/lib/python3.9/site-packages/pysmappee/servicelocation.py", line 227, in load_configuration
self.mqtt_connection_central = self.load_mqtt_connection(kind='central')
File "/usr/local/lib/python3.9/site-packages/pysmappee/servicelocation.py", line 522, in load_mqtt_connection
mqtt_connection.start()
File "/usr/local/lib/python3.9/site-packages/pysmappee/mqtt.py", line 219, in start
self._client.connect(host=config['MQTT'][self._farm]['host'],
File "/usr/local/lib/python3.9/site-packages/paho/mqtt/client.py", line 914, in connect
return self.reconnect()
File "/usr/local/lib/python3.9/site-packages/paho/mqtt/client.py", line 1044, in reconnect
sock = self._create_socket_connection()
File "/usr/local/lib/python3.9/site-packages/paho/mqtt/client.py", line 3685, in _create_socket_connection
return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
File "/usr/local/lib/python3.9/socket.py", line 844, in create_connection
raise err
File "/usr/local/lib/python3.9/socket.py", line 832, in create_connection
sock.connect(sa)
socket.timeout: timed out
That seems indeed related. I think it was around noon that it stopped working.
Smappee status shows the issue is resolved in the meantime. However, seems that there is still an issue. Tried restarting the Smappee and HA, but keep getting ‘socket.timeout: timed out’ error
Sorry, I do not even know Smappee at all, but your error mention Service_location and looking at their manuals it looks like something you need to log in correctly to their site.
Check you setup again as if you where installing it the first time.
the integration is not working yet. This is the error message I get:
Source: components/smappee/init.py:104
First occurred: 13:24:47 (1 occurrences)
Last logged: 13:24:47
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 313, in async_setup
File “/usr/src/homeassistant/homeassistant/components/smappee/init.py”, line 104, in async_setup_entry
File “/usr/local/lib/python3.9/concurrent/futures/thread.py”, line 52, in run
File “/usr/local/lib/python3.9/site-packages/pysmappee/smappee.py”, line 30, in load_service_locations
sl = SmappeeServiceLocation(service_location_id=service_location.get(‘serviceLocationId’),
File “/usr/local/lib/python3.9/site-packages/pysmappee/servicelocation.py”, line 74, in init
File “/usr/local/lib/python3.9/site-packages/pysmappee/servicelocation.py”, line 227, in load_configuration
self.mqtt_connection_central = self.load_mqtt_connection(kind=‘central’)
File “/usr/local/lib/python3.9/site-packages/pysmappee/servicelocation.py”, line 522, in load_mqtt_connection
File “/usr/local/lib/python3.9/site-packages/pysmappee/mqtt.py”, line 219, in start
self._client.connect(host=config[‘MQTT’][self._farm][‘host’],
File “/usr/local/lib/python3.9/site-packages/paho/mqtt/client.py”, line 914, in connect
File “/usr/local/lib/python3.9/site-packages/paho/mqtt/client.py”, line 1044, in reconnect
File “/usr/local/lib/python3.9/site-packages/paho/mqtt/client.py”, line 3685, in _create_socket_connection
File “/usr/local/lib/python3.9/socket.py”, line 844, in create_connection
raise err
File “/usr/local/lib/python3.9/socket.py”, line 832, in create_connection
sock.connect(sa)
