Smappee "hidden" API
As we know Smappee is now charging for the API, but noticed its possible to access an expanded API plus websocket for the smappee without an api
POST: https://app1pub.smappee.net/api/v9/login
JSON_PAYLOAD: {“language”:“en”,“password”:“yourpassword”,“refresh”:1,“userName”:“yourusername”}
gives you a access token
Then you can also access more specific things like usage pr switch with endpoint
GET /api/v9/servicelocation/yourservicelocation/appliances/SWITCH-5?intervalLength=DAY&timestamps=1550876400000&aggregationType=MINUTES_5
Also its an avialable websocket connection on
: wss://ws1pub.smappee.net/websocket
Its also possible to access a websocketed MQTT that is truncted with: https://pro.smappee.net/mqtt (websocket)
At least this is opening some possibilities to extract more detailed data from smappee
Hey, is this still working? Do you use it? I have bought a legacy smappee solar device
