Since a few days, my smappee integration on home assistant has stopped working.
I am getting an unauthorized error.
When I do a post request (with postman), I get an access token, so my credentials are ok.
POST /dev/v3/oauth2/token HTTP/1.1
Host: app1pub.smappee.net
Content-Type: application/x-www-form-urlencoded;charset=UTF-8
grant_type=password&
client_id=[YOUR_APP_ID]&
client_secret=[YOUR_CLIENT_SECRET]&
username=[USER_NAME]&
password=[USER_PASSWORD]
This is my error log, does anyone else have this problem?
Thank you in advance
Logger: homeassistant.config_entries
Source: helpers/config_entry_oauth2_flow.py:201
First occurred: 17 april 2022 09:29:36 (1 occurrences)
Last logged: 17 april 2022 09:29:36
Error setting up entry smappeeCloud for smappee
File "/usr/local/lib/python3.9/site-packages/pysmappee/api.py", line 21, in wrapper
return func(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/pysmappee/api.py", line 67, in get_service_locations
r.raise_for_status()
File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 960, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 401 Client Error: Unauthorized for url: https://app1pub.smappee.net/dev/v3/servicelocation
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 335, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/smappee/__init__.py", line 104, in async_setup_entry
await hass.async_add_executor_job(smappee.load_service_locations)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/pysmappee/smappee.py", line 22, in load_service_locations
locations = self.smappee_api.get_service_locations()
File "/usr/local/lib/python3.9/site-packages/pysmappee/api.py", line 24, in wrapper
self._oauth.token = self.refresh_tokens()
File "/usr/src/homeassistant/homeassistant/components/smappee/api.py", line 43, in refresh_tokens
run_coroutine_threadsafe(
File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 445, in result
return self.__get_result()
File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 390, in __get_result
raise self._exception
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 460, in async_ensure_token_valid
new_token = await self.implementation.async_refresh_token(self.token)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 88, in async_refresh_token
new_token = await self._async_refresh_token(token)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 175, in _async_refresh_token
new_token = await self._token_request(
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 201, in _token_request
resp.raise_for_status()
File "/usr/local/lib/python3.9/site-packages/aiohttp/client_reqrep.py", line 1004, in raise_for_status
raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 401, message='Unauthorized', url=URL('https://app1pub.smappee.net/dev/v3/oauth2/token')
