Hello together,
i bought some Smart+ Classic E27 Dimmable bulbs and tried to pair them with my ZHE.
I’m using the TI CC2531 dongle. ZHE find the bulb as unknown manufacturer…
Here is the log of the pairing.
Device 0x9758 (7c:b0:3e:aa:0a:04:b7:b9) joined the network
[0x9758:zdo] ZDO request ZDOCmd.Device_annce: [0x9758, 7c:b0:3e:aa:0a:04:b7:b9, 142]
[0x9758] Requesting 'Node Descriptor'
Tries remaining: 2
[0x9758] Extending timeout for 0xf9 request
[0x9758] Node Descriptor: NodeDescriptor(byte1=1, byte2=64, mac_capability_flags=142, manufacturer_code=48042, maximum_buffer_size=64, maximum_incoming_transfer_size=0, server_mask=0, maximum_outgoing_transfer_size=0, descriptor_capability_field=3, *allocate_address=True, *complex_descriptor_available=False, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False, *is_valid=True, *logical_type=<LogicalType.Router: 1>, *user_descriptor_available=False)
[0x9758] Discovering endpoints
Tries remaining: 3
[0x9758] Discovered endpoints: [3]
[0x9758:3] Discovering endpoint information
Tries remaining: 3
[0x9758:3] Discovered endpoint information: SizePrefixedSimpleDescriptor(endpoint=3, profile=49246, device_type=256, device_version=2, input_clusters=[4096, 0, 3, 4, 5, 6, 8, 64527], output_clusters=[25])
Received frame on uninitialized device 7c:b0:3e:aa:0a:04:b7:b9 endpoint 13 for cluster: 25
[0x9758:3] Manufacturer: None
[0x9758:3] Model: None
Checking quirks for None None (7c:b0:3e:aa:0a:04:b7:b9)
Considering <class 'zhaquirks.xbee.xbee_io.XBeeSensor'>
Fail because endpoint list mismatch: {232, 230} {3}
Considering <class 'zhaquirks.xbee.xbee3_io.XBee3Sensor'>
Considering <class 'zhaquirks.smartthings.tag_v4.SmartThingsTagV4'>
Fail because endpoint list mismatch: {1} {3}
Considering <class 'zhaquirks.smartthings.multi.SmartthingsMultiPurposeSensor'>
Considering <class 'zhaquirks.netvox.z308e3ed.Z308E3ED'>
Considering <class 'zhaquirks.gledopto.soposhgu10.SoposhGU10'>
Fail because endpoint list mismatch: {11, 13} {3}
Considering <class 'bellows.zigbee.application.EZSPCoordinator'>
device - 0x9758:7c:b0:3e:aa:0a:04:b7:b9 entering async_device_initialized - is_new_join: True
device - 0x9758:7c:b0:3e:aa:0a:04:b7:b9 has joined the ZHA zigbee network
[0x9758](unk_model): started configuration
[0x9758:ZDO](unk_model): 'async_configure' stage succeeded
[0x9758:3:0x0006]: bound 'on_off' cluster: Status.SUCCESS
[0x9758:3:0x0008]: Failed to bind 'level' cluster:
[0x9758:3:0x1000]: Couldn't get list of groups:
[0x9758:3:0x0000]: finished channel configuration
[0x9758:3:0x0019]: finished channel configuration
[0x9758:3:0x0006]: failed to set reporting for 'on_off' attr on 'on_off' cluster:
[0x9758:3:0x0006]: finished channel configuration
[0x9758:3:0x0008]: failed to set reporting for 'current_level' attr on 'level' cluster:
[0x9758:3:0x0008]: finished channel configuration
[0x9758:3:0x0006]: 'async_configure' stage succeeded
[0x9758:3:0x0008]: 'async_configure' stage succeeded
[0x9758:3:0x1000]: 'async_configure' stage succeeded
[0x9758:3:0x0000]: 'async_configure' stage succeeded
[0x9758:3:0x0019]: 'async_configure' stage succeeded
[0x9758](unk_model): completed configuration
[0x9758](unk_model): stored in registry: ZhaDeviceEntry(name='unk_manufacturer unk_model', ieee='7c:b0:3e:aa:0a:04:b7:b9', last_seen=1621601172.1916456)
[0x9758:3:0x0003]: command failed: 'trigger_effect' args: '(2, 0)' kwargs '{}' exception: ''
[0x9758](unk_model): started initialization
[0x9758:ZDO](unk_model): 'async_initialize' stage succeeded
[0x9758:3:0x0006]: initializing channel: from_cache: False
[0x9758:3:0x0008]: initializing channel: from_cache: False
[0x9758:3:0x1000]: initializing channel: from_cache: False
[0x9758:3:0x1000]: finished channel configuration
[0x9758:3:0x0000]: initializing channel: from_cache: False
[0x9758:3:0x0019]: initializing channel: from_cache: False
[0x9758:3:0x0006]: failed to get attributes '['on_off']' on 'on_off' cluster:
[0x9758:3:0x0008]: failed to get attributes '['current_level']' on 'level' cluster:
[0x9758:3:0x0006]: 'async_initialize' stage succeeded
[0x9758:3:0x0008]: 'async_initialize' stage succeeded
[0x9758:3:0x1000]: 'async_initialize' stage succeeded
[0x9758:3:0x0000]: 'async_initialize' stage succeeded
[0x9758:3:0x0019]: 'async_initialize' stage succeeded
[0x9758](unk_model): power source: Mains
[0x9758](unk_model): completed initialization
None: polling current state
[0x9758:3:0x0006]: command failed: 'on' args: '()' kwargs '{}' exception: ''
light.osram_stehlampe_level_on_off: turned on: {'on_off': TimeoutError()}
[0x9758:3:0x0006]: command failed: 'off' args: '()' kwargs '{}' exception: ''
light.osram_stehlampe_level_on_off: turned off:
I already found the bulb on that page: OSRAM Smart+ Classic E27 Dimmable (OSR 5816510) Zigbee compatibility
as an supported bulb for ZHE. Should i maybe use zigbee2mqtt? Do you have some solutions?
Greetings
L0k1
