Hello. Everyone. If anyone is interested, I’ve migrated my Arduino MKR 1000-based code to esphome.
Designed as a controller for a cold room or walk-in refrigerator. It’s similar in concept to a CoolBot unit that tricks a standard window AC unit into getting colder than it normally will (shuts off at 60°F). It does this by turning on a small heater (a 5w power resistor) strapped to the main temp sensor on the AC unit. By turning this heater on, it tricks the AC into thinking the room is warmer than it actually is, and will run the AC down to whatever temp you set. There’s an additional temp sensor on the fins of the AC unit to sense if they are icing up, and to defrost them if necessary. This will chill down to 34°, if desired. A set of two small fans that vent outside air into the room, and a small fan that vents air out. If it’s cold enough outside, these two fans instead of the more expensive to run AC unit.
The code is designed to Config is below. The project utilizes a 5v 2-relay board, 3 Dallas Temperature sensors and a SSD1306 display.
# === Substitutions ===
# Define reusable variables for the project name and type to simplify configuration updates.
substitutions:
type: ESP
# === ESPHome Configuration ===
# Basic settings for the ESPHome integration, defining the device name and its user-friendly display name.
esphome:
friendly_name: "smart-cooler"
comment: Smart Cooler - Cold Room Control System
# === ESP32 Board and Framework ===
# Specify the board and framework type for the ESP32 device.
esp32:
board: esp32-c3-devkitm-1
framework:
type: arduino
# === Global Variables ===
# Define global variables to store and manage device states.
globals:
- id: ac_state # Tracks whether the AC (or heater) is active.
type: bool
initial_value: 'false'
- id: fan_state # Tracks whether the fan is active.
type: bool
- id: deadband_state # Manages the deadband logic to prevent rapid toggling.
type: bool
- id: freeze_recovery # Indicates if freeze recovery mode is active.
type: bool
- id: hysteresis # Temperature hysteresis range to avoid frequent toggling.
type: float
initial_value: '1.0'
- id: margin # Safety margin to prevent fins from freezing.
type: float
initial_value: '4.0'
# === Logging Configuration ===
# Enable logging to monitor the device's behavior.
logger:
level: WARN
# === API Configuration ===
# Enable the API for integration with Home Assistant, including encryption for secure communication.
api:
encryption:
key: "p97Kk5PMQqd+PrebH7TEIzNhwPrxHVqRQnxLKiWZhq0="
# === OTA Updates ===
# Allow Over-The-Air updates with a secure password.
ota:
- platform: esphome
password: "994a754fd02223e9e8143b409cd1ec76"
# === Wi-Fi Configuration ===
# Configure Wi-Fi settings, including a fallback hotspot in case of connection failure.
wifi:
ssid: !secret wifi_ssid
power_save_mode: none
reboot_timeout: 0s
ap:
ssid: "smart-cooler"
password: "BnHdWV9EqyDt"
# === Text Sensors ===
# Provide network-related information (e.g., IP, SSID, MAC address) for diagnostics.
text_sensor:
- platform: wifi_info
ip_address:
icon: "mdi:ip"
ssid:
icon: "mdi:wifi"
bssid:
icon: "mdi:wifi"
mac_address:
name: "Mac Wifi Address"
icon: "mdi:lan-connect"
dns_address:
icon: "mdi:ip"
name: " Currently Running"
icon: "mdi:earth"
lambda: |-
if (id(ac_state)) {
return {"AC"};
} else if (id(fan_state)) {
return {"FANS"};
} else if (id(deadband_state)) {
return {"DEADBAND"};
} else if (id(freeze_recovery)) {
return {"FREEZE"};
} else {
return {"OFF"};
update_interval: 5s
web_server:
sorting_group_id: state_settings
# === Captive Portal ===
# Enable a fallback interface for device setup if Wi-Fi fails.
captive_portal:
# === Web Server ===
# Set up a web server for direct control and monitoring, with authentication.
web_server:
version: 3
auth:
username: saintmoor
password: saintmoor
log: true
sorting_groups:
- id: relay_settings
sorting_weight: -25
- id: temperature_settings
sorting_weight: -20
- id: set_point_settings
name: "Temperature SetPoints"
sorting_weight: -15
- id: state_settings
sorting_weight: -10
# === HTTP Request ===
# Enable HTTP requests for external integrations.
http_request:
useragent: esphome/device
timeout: 10s
verify_ssl: false
# === Time Synchronization ===
# Synchronize the device time with NTP servers.
time:
- platform: sntp
timezone: America/New_York
servers:
- 0.pool.ntp.org
- 1.pool.ntp.org
- 2.pool.ntp.org
# === Number Controls ===
# Define configurable settings for temperature setpoints and hysteresis.
number:
name: "Target Temp" # Target room temperature.
unit_of_measurement: "°F"
icon: "mdi:temperature-fahrenheit"
optimistic: true
min_value: 34
max_value: 121
step: 1
initial_value: 34
restore_value: true
web_server:
sorting_group_id: set_point_settings
name: "Hysteresis Range" # Range for temperature hysteresis.
optimistic: true
min_value: 0.0
max_value: 2.0
step: 0.5
initial_value: 0.5
restore_value: true
web_server:
name: "Freeze Recovery Margin" # Range for freezing temperature value addition.
optimistic: true
min_value: 0
max_value: 4
step: 1
initial_value: 4
restore_value: true
web_server:
# === 1-Wire Sensors ===
# Configure temperature sensors for monitoring room, fins, and outside temperatures.
one_wire:
- platform: gpio
pin: GPIO10
# === i2c Sensors ===
i2c:
sda: 9
scl: 7
scan: true
frequency: 400kHz
# === LED Control ===
# Configure an onboard LED with color effects for status indication.
light:
- platform: neopixelbus
type: GRB
variant: WS2811
pin: GPIO08
icon: "mdi:led-strip"
num_leds: 1
restore_mode: ALWAYS_ON
on_turn_on:
then:
- light.control:
brightness: 25%
effect: Green
effects: # Predefined LED effects for visual feedback.
- addressable_color_wipe: # Solid color effects.
colors:
- red: 100%
green: 0%
blue: 0%
num_leds: 1
reverse: false
colors:
- red: 0%
green: 100%
blue: 0%
num_leds: 1
reverse: false
colors:
- red: 0%
green: 0%
blue: 100%
num_leds: 1
reverse: false
colors:
- red: 100%
green: 100%
blue: 100%
num_leds: 1
reverse: false
- pulse: # Blinking effects.
transition_length: 0.5s
update_interval: 0.5s
min_brightness: 0%
max_brightness: 100%
- pulse:
transition_length: 1s # defaults to 1s
update_interval: 2s
# === Binary Sensors ===
# Monitor various states, such as AC, fan, and freeze recovery status.
binary_sensor:
- platform: status
icon: "mdi:state-machine"
icon: "mdi:earth"
lambda: |-
if (id(ac_state)) {
return true;
} else {
return false;
web_server:
icon: "mdi:earth"
lambda: |-
return true;
} else {
return false;
web_server:
icon: "mdi:earth"
lambda: |-
return true;
} else {
return false;
web_server:
name: "Freeze Recovery"
icon: "mdi:earth"
lambda: |-
return true;
} else {
return false;
web_server:
#=====CONFIG FOR OLED====#
# Control display output for sensor and state information.
font:
- file: 'fonts/arial.ttf'
- file: "fonts/OpenSans-Regular.ttf"
- file: "gfonts://Roboto" # gfonts://family[@weight]
- file: 'fonts/BebasNeue-Regular.ttf'
- file: 'fonts/Silkscreen-Regular.ttf'
image:
- file: mdi:alert-outline
resize: 60x60
- file: mdi:snowflake
resize: 60x60
- file: mdi:radiator
resize: 60x60
- file: mdi:power-off
resize: 60x60
- file: mdi:power-on
resize: 60x60
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
address: 0x3C
i2c_id: bus_a
# reset_pin: D0
auto_clear_enabled: True
show_test_card: true
# update_interval: 5s
pages:
- id: page1
lambda: |-
// it.printf(X, Y,.. (X (Row) and Y (Column))
// Print "Smart Cooler" in top center.
it.printf(it.get_width() / 2, 8, id(roboto_medium), TextAlign::TOP_CENTER, "Smart Cooler");
// Print time in HH:MM format
it.strftime(0, 60, id(bebasneue_large), TextAlign::BASELINE_LEFT, "%H:%M", id(sntp_time).now());
// Print ROOM temperature
if (id(room_temp).has_state()) {
it.printf(127, 23, id(arial_medium), TextAlign::TOP_RIGHT, "%.1f°", id(room_temp).state);
// Print Target temperature
if (id(target_temp).has_state()) {
it.printf(127, 60, id(arial_medium), TextAlign::BASELINE_RIGHT, "%.1f°", id(target_temp).state);
- id: page2
lambda: |-
// Print "Currently Running" in the top center
it.printf(it.get_width() / 2, 8, id(roboto_medium), TextAlign::TOP_CENTER, "Currently Running");
// Determine the text to display
std::string status_text;
if (id(ac_state)) {
status_text = "AC";
status_text = "FANS";
status_text = "DEADBAND";
status_text = "FREEZE";
} else {
status_text = "OFF";
// Print the status text centered at the bottom
it.printf(it.get_width() / 2, it.get_height() - 4, id(bebasneue_medium), TextAlign::BASELINE_CENTER, "%s", status_text.c_str());
- id: page3
lambda: |-
// Print "Target Temp" in top center.
it.printf(it.get_width() / 2, 8, id(roboto_medium), TextAlign::TOP_CENTER, "Target Temp");
// Print Target temperature in baseline center
it.printf(it.get_width() / 2, it.get_height() - 4, id(bebasneue_large), TextAlign::BASELINE_CENTER, "%.1f°", id(target_temp).state);
- id: page4
lambda: |-
// Print "Room Temp" in top center.
it.printf(it.get_width() / 2, 8, id(roboto_medium), TextAlign::TOP_CENTER, "Room Temp");
// Print Room temperature in baseline center
it.printf(it.get_width() / 2, it.get_height() - 4, id(bebasneue_large), TextAlign::BASELINE_CENTER, "%.1f°", id(room_temp).state);
- id: page5
lambda: |-
// Print "FINS Temp" in top center.
it.printf(it.get_width() / 2, 8, id(roboto_medium), TextAlign::TOP_CENTER, "Fins Temp");
if (id(fins_temp).has_state()) {
it.printf(it.get_width() / 2, it.get_height() - 4, id(bebasneue_large), TextAlign::BASELINE_CENTER, "%.1f°", id(fins_temp).state);
- id: page6
lambda: |-
// Print "Outside Temp" in top center.
it.printf(it.get_width() / 2, 8, id(roboto_medium), TextAlign::TOP_CENTER, "Outside Temp");
// Print Outside temperature in baseline center
if (id(ext_temp).has_state()) {
it.printf(it.get_width() / 2, it.get_height() - 4, id(bebasneue_large), TextAlign::BASELINE_CENTER, "%.1f°", id(ext_temp).state);
- id: page7
lambda: |-
// Print "Hysteresis" in top center.
it.printf(it.get_width() / 2, 8, id(roboto_medium), TextAlign::TOP_CENTER, "Hysteresis");
// Print Hystereis Range in baseline center
if (id(hysteresis_range).has_state()) {
it.printf(it.get_width() / 2, it.get_height() - 4, id(bebasneue_large), TextAlign::BASELINE_CENTER, "%.1f°", id(hysteresis_range).state);
- id: page8
lambda: |-
// Print "Recovery Margin" in top center.
it.printf(it.get_width() / 2, 8, id(roboto_medium), TextAlign::TOP_CENTER, "Recovery Margin");
// Print Freeze Recovery Margin in baseline center
if (id(safety_margin).has_state()) {
it.printf(it.get_width() / 2, it.get_height() - 4, id(bebasneue_large), TextAlign::BASELINE_CENTER, "%.1f°", id(safety_margin).state);
- id: starting
lambda: |-
it.printf(it.get_width() / 2, 8, id(roboto), TextAlign::TOP_CENTER, "Smart Cooler");
- id: snowflake
lambda: |-
// Draw the image snowflake at position [x=0,y=0]
it.image(64, 60, id(snowflake_image));
- id: alert
lambda: |-
// Draw the image alert at position [x=0,y=0]
it.image(0, 0, id(alert_image));
- id: power_off
lambda: |-
// Draw the image power_off at position [x=0,y=0]
it.image(0, 0, id(power_off_image));
- id: power_on
lambda: |-
// Draw the image power_on at position [x=0,y=0]
it.image(0, 0, id(power_on_image));
- id: radiator
lambda: |-
// Draw the image radiator at position [x=0,y=0]
it.image(0, 0, id(radiator_image));
# === Sensors ===
# Read and display temperature sensor values.
- platform: uptime
name: "Uptime" # Device uptime in seconds
- platform: internal_temperature
name: "Internal Temperature" # ESP32 internal temperature in °F
accuracy_decimals: 0
device_class: "temperature"
state_class: "measurement"
filters:
- lambda: return x * (9.0/5.0) + 32.0; # Convert Celsius to Fahrenheit
- filter_out: nan
- platform: dallas_temp
address: 0x690417a1115aff28 # ROOM_SENSOR
one_wire_id: dallas_1
name: "Room Temperature"
icon: "mdi:thermometer"
accuracy_decimals: 1
update_interval: 10s
resolution: 9
filters:
- throttle: 1s
- heartbeat: 5s
- debounce: 0.1s
- lambda: return x * (9.0/5.0) + 32.0; # Convert temperature readings to Fahrenheit.
- filter_out: nan
on_value_range:
- above: 125
then:
- logger.log:
level: ERROR
format: "Sensor reading too high! Value: %.2f"
args: [x]
- delay: 30s
- logger.log: "Retrying sensor..."
web_server:
sorting_group_id: temperature_settings
address: 0x990417a10ca3ff28 # FINS_SENSOR
name: "Fins Temperature"
resolution: 9
filters:
- throttle: 1s
- heartbeat: 5s
- debounce: 0.1s
- filter_out: nan
on_value_range:
- above: 125
then:
- logger.log:
level: ERROR
args: [x]
- delay: 30s
web_server:
address: 0x0e0417a116ffff28 # EXT_SENSOR
name: "Outside Temperature"
resolution: 9
filters:
- throttle: 1s
- heartbeat: 5s
- debounce: 0.1s
- filter_out: nan
on_value_range:
- above: 125
then:
- logger.log:
level: ERROR
args: [x]
- delay: 30s
web_server:
# == Other Sensors ==
# Configure target temp, and other sensors
icon: "mdi:earth"
lambda: |-
return id(target_temp).state;
on_value:
then:
- globals.set:
value: !lambda 'return x;'
update_interval: 5s
web_server:
icon: "mdi:earth"
lambda: |-
return id(hysteresis_range).state;
on_value:
then:
- globals.set:
update_interval: 5s
web_server:
name: "Freeze Recovery Temp"
icon: "mdi:earth"
lambda: |-
return 32.0 + id(safety_margin).state;
on_value:
then:
- globals.set:
update_interval: 5s
web_server:
# === Switches ===
# Control relays for heater and outside fans.
switch:
- platform: restart
- platform: gpio
pin: GPIO04
icon: "mdi:radiator"
restore_mode: ALWAYS_OFF
web_server:
sorting_group_id: relay_settings
- platform: gpio
pin: GPIO05
icon: "mdi:fan"
web_server:
name: " Power Switch"
icon: "mdi:power"
optimistic: True
restore_mode: RESTORE_DEFAULT_OFF
turn_on_action:
- logger.log: "Power Turned On!"
- light.turn_on:
brightness: 25%
effect: Green
turn_off_action:
- logger.log: "Power Turned Off!"
- light.turn_on:
brightness: 25%
effect: Red
web_server:
# === Scripts ===
# Define scripts for handling specific tasks, like freeze recovery.
script:
- id: freeze_recovery_script
mode: queued
then:
- lambda: |-
id(freeze_recovery) = true;
ESP_LOGW("freeze_recovery", "Starting freeze recovery process.");
- switch.turn_off: heater
- switch.turn_off: ext_fans
- delay: 60s
- while:
condition:
lambda: "return id(fins_temp).state <= 32.0 + id(safety_margin).state;"
then: # Logic to recover from fins freezing.
- delay: 60s
- lambda: |-
id(freeze_recovery) = false;
ESP_LOGI("freeze_recovery", "Recovery process complete.");
# === Main Logic ===
# Control relays and temperature settings based on sensor data and state variables.
interval:
- interval: 16s
then:
- display.page.show: page1
- component.update: oled_display
- delay: 3s
- display.page.show: page2
- delay: 3s
- display.page.show: page3
- delay: 2s
- display.page.show: page4
- delay: 2s
- display.page.show: page5
- delay: 2s
- display.page.show: page6
- delay: 2s
- display.page.show: page7
- delay: 2s
- display.page.show: page8
- delay: 2s
- interval: 15s
then:
- lambda: |-
float upper_threshold = id(target) + id(hysteresis);
float lower_threshold = id(target) - id(hysteresis);
float outside_temp = id(ext_temp).state;
float cooler_temp = id(room_temp).state;
bool is_ac_active = id(ac_state);
bool is_fan_active = id(fan_state);
bool is_deadband_active = id(deadband_state);
bool is_freezing = id(fins_temp).state <= 32.0;
bool is_freeze_recovery_active = id(freeze_recovery);
bool is_power_on = id(power_switch);
bool is_ext_temp_cooling = outside_temp <= (cooler_temp - 20);
bool is_room_above_upper = cooler_temp > upper_threshold;
bool is_room_below_lower = cooler_temp <= lower_threshold;
// Exterior Cooling Logic
if (id(power_switch).state == 1) {
if (is_ext_temp_cooling && is_room_above_upper && !is_freeze_recovery_active) {
if (id(ac_state)) {
ESP_LOGD("logic", "FANS are on; turning off heater.");
id(heater).turn_off();
id(ac_state) = 0;
id(ext_fans).turn_on();
id(fan_state) = 1;
} else {
id(ext_fans).turn_off();
id(fan_state) = 0;
// Heater Control Logic with Hysteresis
if (is_deadband_active && !is_freezing && id(room_temp).state >= upper_threshold && !is_freeze_recovery_active) {
ESP_LOGW("logic", "Room temperature above upper threshold; turning on heater.");
id(heater).turn_on();
id(ac_state) = 1;
// id(ext_fans).turn_off();
// id(fan_state) = 0;
id(deadband_state) = 0;
} else if (!is_freezing && !is_deadband_active && id(room_temp).state > id(target_temp).state && !is_freeze_recovery_active) {
ESP_LOGW("logic", "Room temperature above target; keeping heater on.");
id(ac_state) = 1;
} else if (is_room_below_lower && is_ac_active) {
ESP_LOGW("logic", "Room temperature below lower threshold; turning off heater.");
id(ac_state) = 0;
id(deadband_state) = 1;
id(fan_state) = 0;
} else if (is_room_below_lower && !is_ac_active) {
ESP_LOGW("logic", "Room temperature below lower threshold; keeping heater off.");
id(ac_state) = 0;
id(fan_state) = 0;
} else if (id(power_switch).state == 0) {
ESP_LOGW("logic", "Power is off. Controller is not running.");
id(ac_state) = 0;
id(fan_state) = 0;
