And your experience with T-Lock has been good with ZHA? I find with Zigbee2Mqtt there is a solid 1-3 second delay when unlocking/locking from the UI? Do you experience the same?
Yes it has been perfectly fine with one exception.
As we renovated a bit last year we had several power outages due to electrical work. The lock did not automatically reconnect to the network after power came back. I have to pair it again each time (though the entity names are maintained so it’s pretty painless. The issue is that it breaks all my related automations til I pair it.
I’d say 1-3 seconds is typical for me too. But I rarely unlock it from the UI.
I looked into it and my coordinator is only compatible with ZHA according to the guy who built it.
Hi all, regarding the T-Lock, I’m assuming (maybe incorrectly) that you can only program the user pin codes from the lock itself, not from HA?
No, after you have done the master you can do the rest from HA using scripts.
I use automations to activate certain codes for tradies and our cleaner based on calendar events.
This is my Lock manager dashboard consisting entirely of stolen ideas from the forums.
Very cool, thanks for the info. Time to order one I think.
Any chance of getting a copy of the code you have put together for your lock manager dashboard? This would be really useful. Thanks.
I’d also love to see the code when you have a chance.
This is the lovelace card:
header:
image: https://www.ryadel.com/wp-content/uploads/2017/11/IT-Security.jpg
type: picture
show_header_toggle: false
entities:
- type: custom:hui-element
card_type: vertical-stack
cards:
cards:
card_type: horizontal-stack
cards:
- type: entities
entities:
- type: custom:text-input-row
entity: input_text.slot_id
entity: input_text.user_pin
cards:
cards:
- type: entity-button
tap_action:
action: call-service
service: script.clear_fields
hold_action:
action: more-info
show_icon: false
entity: script.clear_fields
icon_height: 25px
cards:
- type: custom:button-card
entity: switch.tradie_mode
show_icon: true
show_state: false
state:
- value: 'on'
- value: 'off'
styles:
card:
- height: 80px
- width: null
entity: switch.holiday_mode
show_icon: true
show_state: false
state:
- value: 'on'
- value: 'off'
styles:
card:
- height: 80px
- width: null
- type: entities
entities:
- entity: input_select.lock
card_mod:
style:
hui-generic-entity-row $: |
state-badge {
display: none;
- entity: script.add_code
- entity: script.remove_code
- entity: script.add_single_use_code
- entity: script.enable_code
- entity: script.disable_code
- type: entities
entities:
- lock.front_door_lock
- lock.back_door_lock
type: entities
state_color: false
Here is my ‘package’ called locks.yaml
input_text:
slot_id:
initial: ""
user_pin:
initial: ""
input_select:
lock:
options:
- Front Door
- Back Door
initial: Front Door
script:
add_code:
alias: Add Lock Code
icon: mdi:key-plus
variables:
slot_id: "{{ states('input_text.slot_id') | int }}"
user_pin: "{{ states('input_text.user_pin') | int }}"
lock: >
{% if is_state("input_select.lock", "Front Door") %} lock.front_door_lock
{% elif is_state("input_select.lock", "Back Door") %} lock.back_door_lock
{% endif %}
mode: single
sequence:
- service: zha.set_lock_user_code
entity_id: "{{ lock }}"
code_slot: "{{ slot_id }}"
user_code: "{{ user_pin }}"
- service: logbook.log
name: Lock code added
message: "slot: {{ slot_id }} on {{ lock }} was updated."
- service: notify.mobile_app_pixel_4a
message: "slot: {{ slot_id }} was updated with a new code: {{ user_pin }}"
title: New pin - {{ states('input_select.lock') }}
ttl: 0
priority: high
channel: "Locks"
remove_code:
alias: Remove Lock Code
icon: mdi:key-minus
variables:
lock: >
{% endif %}
mode: single
sequence:
- service: zha.clear_lock_user_code
name: Lock code removed
message: "slot: {{ slot_id }} was removed from {{ states('input_select.lock') }} Lock"
message: "slot: {{ slot_id }} was deleted on {{ states('input_select.lock') }} Lock"
title: Pin removed - {{ states('input_select.lock') }}
ttl: 0
priority: high
channel: "Locks"
disable_code:
alias: Disable Lock Code
icon: mdi:account-cancel
variables:
lock: >
{% endif %}
mode: single
sequence:
- service: zha.disable_lock_user_code
name: Lock code disabled
message: "slot: {{ slot_id }} was disabled on {{ states('input_select.lock') }}"
title: Pin disabled - {{ states('input_select.lock') }}
ttl: 0
priority: high
channel: "Locks"
enable_code:
alias: Enable Lock Code
icon: mdi:account-check
variables:
lock: >
{% endif %}
mode: single
sequence:
- service: zha.enable_lock_user_code
name: Lock code enabled
message: "slot: {{ slot_id }} was enabled on {{ states('input_select.lock') }}"
message: >
title: Pin enabled
ttl: 0
priority: high
channel: "Locks"
clear_fields:
alias: Clear Input Text Fields
mode: single
sequence:
- service: input_text.set_value
entity_id:
- input_text.slot_id
- input_text.user_pin
value: ""
add_single_use_code:
alias: Add Single Use Code
mode: single
icon: mdi:numeric-1-circle-outline
variables:
slot_id: "111"
lock: >
{% endif %}
sequence:
name: Single use Code Created
message: on {{ states('input_select.lock') }}
message: "{{ user_pin }}*"
title: "Single use Code Created - {{ states('input_select.lock') }}"
ttl: 0
priority: high
channel: "Locks"
color: yellow
- service: notify.mobile_app_kates_s21
ttl: 0
priority: high
color: yellow
#### Lock Summary #####################################################################
#### Source: https://community.home-assistant.io/t/wildcard-entities-card/72969/3
template:
- sensor:
- name: Lock Summary
state: >
{%-for state in states.lock
if state.state== "unlocked" -%}
{%-if loop.last-%}
{%-if loop.index > 0-%}
{%-for state in states.lock if state.state == "unlocked" -%}
{{state.name | replace('Lock', '')}}{%-if not loop.last -%}{%-if(loop.index+1==loop.length)%} & {%else%}, {%endif-%}{%-else%} unlocked{%endif-%}
{%-endfor-%}
{%-endif-%}
{%-endif-%}
{%-else-%}
All locked
{%-endfor-%}
icon: >
{%-if loop.last-%}
mdi:lock-alert-outline
{%-endif-%}
{%-endif-%}
{%-else-%}
mdi:lock-check-outline
{%-endfor-%}
attributes:
count: |-
if(state.state=="unlocked")-%}
{%-if loop.last-%}
{{loop.length}}
{%-endif-%}
{%-endif-%}
{%-else-%}
0
{%-endfor-%}
history_1: "{{ state_attr('sensor.lock_summary', 'history_1') }}"
history_2: "{{ state_attr('sensor.lock_summary', 'history_2') }}"
history_3: "{{ state_attr('sensor.lock_summary', 'history_3') }}"
history_4: "{{ state_attr('sensor.lock_summary', 'history_4') }}"
history_5: "{{ state_attr('sensor.lock_summary', 'history_5') }}"
history_6: "{{ state_attr('sensor.lock_summary', 'history_6') }}"
history_7: "{{ state_attr('sensor.lock_summary', 'history_7') }}"
history_8: "{{ state_attr('sensor.lock_summary', 'history_8') }}"
history_9: "{{ state_attr('sensor.lock_summary', 'history_9') }}"
history_10: "{{ state_attr('sensor.lock_summary', 'history_10') }}"
And the automation to set the unlock history is posted 2 weeks earlier Here
I use the tradie mode and holiday mode to enable and disable various automations. e.g tradie mode stops my doors auto locking and disables my phone getting notifications for motion alerts.
Edit: made some improvements
Edit Jun 2022. more improvements
Thanks for sharing that. I’m not sure Z2M supports sending codes, might have to do some more digging.
Ahh right. ZHA has built in services which I am calling. Hope you can find a solution
Did you get anywhere with finding a HA-compatible smart lock with fingerprint access? I’m in NZ and looking for one of these too.
Hi all, have just installed the lock. Quick question, when the door looks, it seems to go through the process twice, and the keypad also flashes up twice. Is that normal?
Is the bolt having difficulty extending fully?
@SgtBatten yep that was it… after I took a second look I noticed it… drilled like a madman and problem fixed…
is the Zigbee paring fairly straightforward?
Yes it was as easy as entering the network pairing mode (option 7 I think) on the lock and pressing 1 to join while searching for new devices in home assistant (I use zha)
You show no information, not even whether it is zigbee, zwave wifi.
Hi, I’ve been checking what lock you were talking about but failed to find it. Could you please share what it was? Thank you.
This is the one I have on my garage/front door. Works with Zigbee2mqtt
