Smart Digital Humidistat
After tearing my hair out with the inaccurate Honeywell Digital Humidistat and not having enough conductors on my thermostat cable to control my whole-home humidifier via Ecobee, I went the DIY route. My first ESPHome project.
Parts are simply ESP32, a relay, and SHT45 humidity sensor (very accurate!). Weather forecast is pulled via API and used to predict the temperature of the indoor pane of the windows. Using this temperature, dew point is calculated, and target RH% is a few % below this to prevent condensation. With this the relay is switched on/off using a bit of hysteresis.
I still have some work to do to cover the scenario where wifi / internet / API fails and I can’t get a forecast, I’m not sure what will happen as things stand.
esphome:
  friendly_name: esp32_humidistat
esp32:
  board: adafruit_feather_esp32_v2
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
# Enable Home Assistant API
api:
  encryption:
    key: "<redacted>"
  services:
  - service: set_rh_headroom
    variables:
      headroom: float
    then:
      - globals.set:
          value: !lambda 'return headroom;'
  - service: set_rh_ceiling
    variables:
      ceiling: float
    then:
      - globals.set:
          value: !lambda 'return ceiling;'
ota:
  password: "<redacted>"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp32-Humidistat"
captive_portal:
#TODO: check https://www.connaxio.com/projects/co2_sensor/
i2c:
  sda: GPIO22
  scl: GPIO20
  scan: True
switch:
  - platform: gpio
    pin: GPIO5
    name: "Humidifier Control Relay"
    internal: true
binary_sensor:
    name: "Humidifier Control Relay State"
    lambda: |-
      if (id(my_relay).state) {
        return true;
      } else {
        return false;
http_request:
  useragent: esphome/device
  timeout: 10s
  - platform: sht4x
    temperature:
    humidity:
      name: "Relative Humidity"
      unit_of_measurement: "%"
    name: "Minimum Forecast Outdoor Temperature"
    unit_of_measurement: "°C"
    device_class: "temperature"
    state_class: "measurement"
    name: "Relative Humidity Headroom"
    device_class: "humidity"
    update_interval: 60s
    lambda: |-
      return id(RH_headroom);
    name: "Relative Humidity Ceiling"
    lambda: |-
      return id(RH_ceiling);
    name: "Target Humidity"
    update_interval: 1min
globals:
  - id: RH_headroom # we want some margin from the dew point
    type: float
    restore_value: true
    initial_value: '5.0'
  - id: RH_ceiling # in summer we don't want to keep humidifying
    type: double
    restore_value: True
    initial_value: '50'
interval:
  - interval: 1min
    then:
      - http_request.get:
          url: https://api.openweathermap.org/data/2.5/forecast?lat=43.631770&lon=-79.516250&units=metric&appid=<redacted>
          headers:
            Content-Type: application/json
          verify_ssl: false
          on_response:
            then:
              - lambda: |-
                  auto value = id(http_request_data).get_string();
                  json::parse_json(value, [](JsonObject root) {
                    float min_temp_min = root["list"][0]["main"]["temp_min"]; # find the minimum forecast temp over next several hours
                    for(int i = 1; i < 4; i++) {   # need to paramterize time window
                      float temp_min = root["list"][i]["main"]["temp_min"];
                      if(temp_min < min_temp_min) {
                          min_temp_min = temp_min;
                    id(min_temp).publish_state(min_temp_min);
                  float window_interior_thermal_resistance = 1.4; # based on IR gun readings inside and out, this my window performance
                  float window_exterior_thermal_resistance = 2.6;
                  double predicted_window_temp = (id(my_temperature).state * window_interior_thermal_resistance + id(min_temp).state * window_exterior_thermal_resistance) / (window_interior_thermal_resistance + window_exterior_thermal_resistance);
                  ESP_LOGD("update forecast", "predicted_window_temp: %f", predicted_window_temp);
                  double humidity_target_value = 100* exp(17.27 * predicted_window_temp / (243.04 + predicted_window_temp) - 17.27 * id(my_temperature).state / (243.04 + id(my_temperature).state)); # dew point calc
                  humidity_target_value -= id(RH_headroom);
                  humidity_target_value = min(humidity_target_value, id(RH_ceiling));
                  id(humidity_target).publish_state(humidity_target_value);
  - interval: 1min
    then:
      - lambda: |-
          static bool relay_on = false;
          if (relay_on) {
            if (id(my_humidity).state > id(humidity_target).state + 2.5) { # 2.5 for hysteresis
              id(my_relay).turn_off();
              relay_on = false;
          } else {
            if (id(my_humidity).state < id(humidity_target).state - 2.5) {
              id(my_relay).turn_on();
              relay_on = true;
Thanks for the write-up.
Just for my complete understanding, could you share more details on your setup? For example, what humidifier are you controlling and how would certainly inspire me!
