Smart electric fireplace
Anyone using a smart (wifi / zwave / zigbee) electric fireplace where there is an existing integration developed already?
If so what products are out there?
I’ve seen these “sideline” wifi fireplaces which look reasonable but can’t find an integration.
Also see there is an “intellifire” integration available but that looks too be a wifi add on module for controlling the igniter I assume on a gas fireplace.
Seeing if there is already a product that has easy integration into HA before I’ve start going down the ESP8266 route. Preference for integration so i I can get low,medium,high heat settings and similar control rather than just on or off.
Oh and preferably local support, not a big fan of cloud based products :slight_smile:
Cheers
I am also looking at getting an Electric Fireplace that I can control via HomeAssistant (or MQTT). Did you ever get one / have any luck implementing it?
Unfortunately no, not yet. Probably getting solar w/ batteries first then will get. Really want a flame effect fireplace that works like a heat pump (rather than glorified fan heater)
I am also on the same hunt. One option I’m looking at is finding an electric fireplace with an RF remote that is supported by the Bond hub. If there is such a remote, then that should be enough to give reasonable control through home assistant integrated with the bond hub. I do that now for fans and motorized outdoor shades from Sunsetter.
