Smart energy meter DIN rail
I’m looking for a smart energy meter to be placed on a DIN rail compatible with home assistant (in any way) of course.
I installed some Innr zigbee plugs to get consuption from some appliances now I would need something that could be able to monitor “all the rest”.
Thank You for your suggestions
Regards
M.
Shelly 4 Pro - 4x10 amp switches + power consumption information via wifi
SDM120M - power consumption information via modbus (need modbus USB converter)
you can also see some other products from their site which may fit to your needs http://www.eastrongroup.com/products/10.html
If you are familiar with diy projects, I can recommend for you:
https://github.com/arendst/Sonoff-Tasmota/wiki/PZEM004T-Energy-Monitor
and of course you can put all in the DIN riley casing:
https://bit.ly/2Uq0HqQ
Is there any component or custom component to monitor the wattmeter output in a HA graph?
Is something like this what you want?
That is so cool!! Yes, that is exactly what I need indeed!
How did you mesure the power consumtion?
I’m using now 2 approaches simultaneously:
A ZMAI-90 ?
They work real well.
