Smart EV Charging Socket – Power-based detection with cooldown lock
This blueprint provides a robust and event-driven solution to manage an EV charging socket using real power consumption detection, instead of timers or fixed schedules.
It was designed for small EVs and city cars (such as Citroën AMI–style vehicles), but it works with any charger connected to a smart socket with power monitoring.
How it works
- The automation runs a probe at a configurable interval (default: every 30 minutes).
- During the probe, the socket is turned ON and the system waits a short stabilization delay.
- If the measured power exceeds a configurable threshold (default: 500 W), real charging activity is detected.
- The socket remains ON while charging is in progress.
- Charging is considered finished when power drops below a low threshold for a stable period (default: below 30 W for 3 minutes).
- The socket is automatically turned OFF at the end of the charge.
- The end-of-charge timestamp is stored in an
input_datetimehelper. - A cooldown lock (default: 12 hours) prevents further probes until the next realistic charging window.
Why this approach
- Avoids continuous polling loops
- Prevents unnecessary ON/OFF cycles
- No repeated checks during charging
- Safe across Home Assistant restarts
- Matches real-world EV usage (typically one charge per day)
- Fully event-driven using
wait_for_trigger
Key features
- Power-based charging detection
- Stable end-of-charge recognition
- Configurable probe interval and thresholds
- Cooldown lock after charging
- Works with any smart plug providing power data
- Home Assistant UI-friendly blueprint
Requirements
- Smart socket with power monitoring
- One
input_datetimehelper to store the last charge time - Recent Home Assistant version (UI automation schema)
Configuration notes
- If your charger does not drop below 30 W at the end of charging, increase the stop threshold (e.g. 50–80 W).
- Cooldown duration can be adjusted to match your charging habits.
- All parameters are configurable through blueprint inputs.
Tested scenario
Tested with:
- Smart plugs with integrated power sensors
- Small EV chargers with long idle phases
- Daily charging patterns (1 charge per day)
Feedback, suggestions and improvements are welcome.
I hope this blueprint can be useful to others managing EV charging through Home Assistant.
blueprint:
name: Smart EV Charging Socket (Power detection + Cooldown)
description: >
Automatically manages an EV charging socket using power consumption detection.
Periodically probes the socket, detects real charging via power threshold,
turns the socket off at end of charge, and applies a cooldown lock.
domain: automation
input:
charger_socket:
name: EV charger socket
description: Smart socket used to power the EV charger
selector:
entity:
domain: switch
power_sensor:
description: Sensor reporting charger power in Watts
selector:
entity:
domain: sensor
device_class: power
last_charge_datetime:
name: Last charge helper
description: input_datetime helper used as cooldown lock
selector:
entity:
domain: input_datetime
probe_interval:
name: Probe interval (minutes)
default: 30
selector:
number:
min: 5
max: 120
step: 5
unit_of_measurement: min
probe_delay:
name: Probe delay (seconds)
default: 30
selector:
number:
min: 5
max: 120
step: 5
unit_of_measurement: s
start_power:
name: Charging start threshold (W)
default: 500
selector:
number:
min: 100
max: 3000
step: 50
unit_of_measurement: W
stop_power:
name: Charging end threshold (W)
default: 30
selector:
number:
min: 10
max: 200
step: 5
stop_duration:
name: Charging end duration (minutes)
default: 3
selector:
number:
min: 1
max: 10
step: 1
cooldown_hours:
name: Cooldown after charging (hours)
default: 12
selector:
number:
min: 1
max: 48
step: 1
unit_of_measurement: h
mode: single
- platform: time_pattern
minutes: "/{{ probe_interval }}"
condition:
- condition: template
value_template: >
{% set last = states(last_charge_datetime) %}
{% if last in ['unknown','unavailable',''] %}
true
{% else %}
{{ (now() - strptime(last, '%Y-%m-%d %H:%M:%S')).total_seconds() >
(cooldown_hours | int * 3600) }}
{% endif %}
# Probe: turn socket ON
- service: switch.turn_on
entity_id: !input charger_socket
- delay:
seconds: !input probe_delay
- choose:
# Charging detected
- conditions:
- condition: numeric_state
entity_id: !input power_sensor
above: !input start_power
sequence:
# Wait for end of charge
- wait_for_trigger:
- platform: numeric_state
below: !input stop_power
for:
minutes: !input stop_duration
timeout: "14:00:00"
continue_on_timeout: false
# Turn socket OFF
- service: switch.turn_off
# Save end-of-charge timestamp
- service: input_datetime.set_datetime
entity_id: !input last_charge_datetime
datetime: "{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"
default:
# Not charging → turn OFF immediately
