Hello all,
My goal is to create a smart window for privacy that can be adjusted from opaque to translucent to clear. I know there are several brands that create “smart film” that can be stuck to a window to provide this functionality. Have any of you integrated smart film into home assistant? If so, is there a brand/hardware/integration already available? How did you do it?
If not, looks like it might be easy to do. Looks like most use a low voltage (24-60VAC) circuit with transparency adjustable by voltage for control. I would think a dimmer may be used to control it as long as we limit to voltage to the maximum voltage. Perhaps an existing Tasmota compatible device and a transformer would work?
