this is going to be a long post so I apologise in advance, but the essence of it is that I would like to ascertain my options regarding smart heating, and while I’m a software engineer and can handle that side of things no problem, the hardware side I am far worse at and have basically zero knowledge on heating systems.
The situation at the moment is, I bought a house recently (in Ireland) and my house (built around 1999) has a gas boiler that heats both the house via radiators, and the water via a cylinder.
There is a Danfoss programmer controlling both of these (not sure the exact model, but looks like a Danfoss CP715 Si based on trying to search similar ones on the internet).
There is also a Danfoss thermostat (again based on searching the internet my best guess would be Danfoss RET M) that controls the heating.
So what I ultimately want is a system that integrates into my Home Assistant setup and I can control from there.
The specific things that I want though are:
- Needs to be 100% local, it can be wifi and have internet stuff so long as it works 100% without that, as I will be blocking it from accessing the internet on the router
- I would very strongly prefer if it would be both smart and dumb, by which I mean, if my Home Assistant and/or network goes down, I’d like to still be able to have at least basic heating, even if it’s just very dumb fully manual heating by pressing a button to turn the heating on and pressing it to turn it off
Additionally, some of the radiators in my house do have a valve on them to adjust the heating, but some don’t. I don’t know if it’s possible to add these valves, there are some caps that look like they might be there to hide the connection point for a valve, but I don’t know how to find out if that’s the case.
Ideally, I would like to be able to have control over temps in individual rooms as well, though this is not a requirement.
Right now, the boiler is a fairly old one and I will need to replace it at some stage, it’s mostly working still, but has started to show its age.
Additionally, while I’m doing that, I would be very happy to replace it with a combi boiler instead so I don’t have to deal with a cylinder (for my needs, a cylinder doesn’t make a huge amount of sense as it can be hard to anticipate the amount of hot water I’ll need so heating the cylinder overnight ends up being inefficient overall).
So now comes the part where I ask for help. I’m feeling a bit overwhelmed with all of the details here, does the boiler affect the rest, do I need to just put TRVs on radiators and not mess around with anything else to get it smart, are there even options that are both smart and dumb at the same time, …
So I’d like to get some help on this.
I’ve considered also an option of simply making the existing system smart by doing something really dumb like placing a couple of fingerbots to control the programmer and putting a camera or some sort of sensors on the programmer display so I can get status info. Surely there’s a better way, but I’m open to this option as well
So with all that context here, I’m going to ask a few questions to try and make this post a little easier to action, but I definitely have lots of missing knowledge so if anyone has comments rather than answering the below questions it will be much appreciated.
- Is replacing the boiler something I need to consider in this (as in, if I switch to a combi boiler does that somehow mean potentially a thermostat or something I go with will become incompatible)?
- Can any radiator take a smart TRV even if there’s currently no knob on it to adjust?
- What would be a good option for fully local, dumb/smart devices for this? Maybe if the answer to 2. is yes an option is to put TRVs on all the radiators and set the programmer and thermostat to always be on, but then I’d still have the boiler on all the time which I don’t want so I guess I still need a way to deal with that, but not sure what would be a way to deal with that then while retaining the dumb/smart thing
Appreciate any thoughts, comments, …
