I have been searching an reading for weeks, months to find a good solution. I can’t seem to find it. So I kinda have my own idea that sound doable. If anybody has advice or tips?
Current situation: I have an old oil burner (Viessmann Vitola Uniferral 4702) with a wired thermostat Theben Ram 784. So this is an on/off system. The thermostat is fixed on the wall in the kitchen. At this moment the kitchen is warm, but other rooms are cold. While I don’t need the kitchen to be warm.
So, I would need a a smart wireless thermostat that I can place in the room where I am. Next to that I would need smart TRV’s, preferably Zigbee, so I can use it on MQTT. If I want to heat the bathroom half hour before my wake up alarm, I would be able to only heat that room.
I looked at Tado, Netatmo, Bosch, Hombli… Only Tado and Netatmo seems to be able to connect on on/off heaters. I didn’t found any solution for the others. But then they don’t have Zigbee TRV’s and I have to connect HA with their ecosystem, which I don’t like.
Now, my idea would be this:
I use Zigbee TRV’s (tuya, bosch, sonoff) in all rooms. I remove the old on/off thermostat and connect a Zigbee Relay (on/off) on the 2-way cable of the old thermostat. This way I can send the command with HA to the relay that puts the heater on and off, based on the temperature settings of the rooms. Since I have the temperature of each room and I can set the wanted temperature, I can automate everything in HA.
Is that such a bad idea? It seems so cheap, so efficient, so easy to set up.
about 20-30€ for a TRV and 20€ for a relay. So less than 200€ instead of the 600+€ if I use Tado.
(It might be smart to avoid using the relay and use a wireless thermostat that has an integration with HA. I can use this thermostat in the living room, so I don’t need 3 TRV’s for that room. And I can set it locally if I have a problem with my HA.)
What do you think?
