Smart Home Heating with HEATHER
Project HEATHER
This project consolidates all the components of my Home Assistant heating control system previously published as separate Github Gists and HA community pages.
The new name HEATHER is coined for the consolidated project and Github repository comprising:
  • Three Home Assistant blueprints
    • Heating X2
    • Calendar Switch Y2
    • Zone Switch Z2
  • The Heating XYZ Code Generator
    • A series of WORD (.docx) mail merge files that are used to create YAML files for Home Assistant configuration
    • An example EXCEL (.xls) mail merge DATA file
  • The packaged script Logfile Entry
The files in this repository supersede all previous versions of the above-named files in other locations.
This reorganisation is made solely for ease of maintenance. The current version (2.4) is compatible with all previous version 2.x installations (not with 1.x, which is deprecated and no longer supported).
To get started
Download and read the Guide PDF.
It contains full instruction on how to install and configure a full home smart heating system using the blueprints, script, and code generator in the HEATHER repository.
If you find the ideas in this project useful, please Buy Me a Coffee
Hi Andy,
Firstly, sorry for not replying to your suggestions on the original topic about how I might be able to achieve different temperature settings depending on house occupancy (Heating X2: Schedule Thermostats with Calendars [CLOSED] - #32 by AndySymons). I’d missed the post in the changeover to this new topic. All good suggestions & I’ll investigate the best way forwards (I like the idea of different automations that can be selected for the same ā€œzoneā€).
Since my last posts I’ve moved my Home Server across onto a new system & Iā€˜ve been setting Home Assistant up again from scratch as a clean install. I’m not sure if it’s due to newer versions of Home Assistant (I’m currently running 2024.8.3), but I’ve had a few issues getting Heating X2 running.
It seems to be based around logging and errors are produced if I don’t generate the specific logfile & notify service (& specify them in the automation). ie If I decide that I don’t want to use logging, the script.logfile_entry causes an error.
I have logfile_entry.yaml installed as a package and it is recognised by the automations. By way of example, I have two automations both based on the HeatingX2 blueprint. Zone 1 is configured to use a notification service notify.zone1_log (held withing /config/log_files/zone1.log), but for Zone 2 I have not specified logging.
I get the following error in the Main Home Assistant log when changing the temperature setting for Zone 2:
2024-09-01 11:07:22.681 ERROR (MainThread) [homeassistant.components.script.logfile_entry] Log File Entry: If at step 1: Error executing script. Invalid data for call_service at pos 1: not a valid value for dictionary value @ data['entity_id']
2024-09-01 11:07:22.682 ERROR (MainThread) [homeassistant.components.script.logfile_entry] Log File Entry: Error executing script. Invalid data for if at pos 1: not a valid value for dictionary value @ data['entity_id']
2024-09-01 11:07:22.682 ERROR (MainThread) [homeassistant.components.automation.zone_2_heating] Zone 2 heating: Error executing script. Invalid data for call_service at pos 1: not a valid value for dictionary value @ data['entity_id']
2024-09-01 11:07:22.682 ERROR (MainThread) [homeassistant.components.automation.zone_2_heating] Error while executing automation automation.zone_2_heating: not a valid value for dictionary value @ data['entity_id']
If I look at the Automation Trace for Zone 2 I get:
Error: not a valid value for dictionary value @ data['entity_id']
 Result:
 params:
   domain: script
   service: logfile_entry
   service_data:
     notification_service: ''
     logfile_title: Heating X2
     message_preamble: Zone 2 heating
     message_body: '---'
   target: {}
 running_script: true
 child_id:
   domain: script
   item_id: logfile_entry
If I compare this to zone 1, which does have a logfile:
Executed: 1 September 2024 at 11:05:05
Result:
params:
  domain: script
  service_data:
    notification_service: zone1_log
    message_preamble: Zone 1 heating
    message_body: '---'
  target: {}
child_id:
  domain: script
Zone 1 seems to be functioning correctly. Of additional note, in order to setup the notify service using the File Integration I had to add the following to my Home Assistant config, else I had permission issues:
homeassistant:
allowlist_external_dirs:
- ā€œ/config/log_files/ā€
The requirement for allowlist_external_dirs is specified at File - Home Assistant
Again, thank you for this great automation. I’m looking forward to getting it fully up-and-running before the winter kicks in!
Hello, i have the same Problems.
I didnt us Zones but the Problem is the same with my thermostat.
I made also an GitHub issue.
Why there is no reaction. Neither here nor on Github ?
This looks like a bug that I fixed a couple of days ago in logfile_entry.yaml (someone else raised it on Github)
It occurs when no logfile is specified
Try the new version
Sorry for the inconvenience :pray:
Thanks for the reply & the fix Andy. I’ve copied the new logfile across, but in the mean time I’d setup logging on my instances, so when I get the chance I’ll try a new instance without logging.
Hi Andy, what a fantastic (lot) of work you’ve done. I am working through your pdf guide and using your code generator.
One silly question (sorry) you say in page 18 section 7.4 General mail merge procedure at 8. ā€œIn Home Assistant, find the file xxxx.yamlā€. Which file are you referring too?
Hi Andy,
great work here, at first glance this looks like fantastic blueprint/project, but also quite complicated.
And just to let you know, the links in your PDF dont seem to be working?
I’m affraid im running into problems already with the code generators…
The input-numbers generator generates a whole bunch of duplicate entries.
I have four TRV’s in my living room that i have given different Locations in the xls sheet. i think these locations are supposed to be added to the generated entities in the generator? or do i have to only create one entity for my living room?
Further, what is not yet clear to me: so i have 8 TRV’s throughout my house, but one main thermostat that controls the actual heating that should turn on/off depending on TRV status. should i set this main thermostat as ā€œzone1ā€ or will i select this somewhere down the line in the setup progress? i havent seen any mention of it in the PDF
I simply mean that you have to iterate through the instructions for each of the files
02 Heating XYX code generator for input_texts.yaml.docx
03 Heating XYX code generator for input_numbers.yaml.docx
04 Heating XYX code generator for input_booleans.yaml.docx
05 Heating XYX code generator for timers.yaml.docx
06 Heating XYX code generator for binary_sensors.yaml.docx
07 Heating XYX code generator for templates.yaml.docx
08x Heating XYX code generator for automations X.yaml.docx
08y Heating XYX code generator for automations Y.yaml.docx
08z Heating XYX code generator for automations Z.yaml.docx
09x Heating XYX code generator for dashboard cards X.yaml.docx
09y Heating XYX code generator for dashboard cards Y.yaml.docx
09z Heating XYX code generator for dashboard cards Z.yaml.docx
The subsequent sections give details for each YAML type.
I am due to refresh the manual soon and will take your comment into account :slight_smile:
If you find the ideas in this repository useful, please remember to Buy Me a Coffee
Sorry, I must have selected the wrong option when saving to PDF from WORD :face_with_open_eyes_and_hand_over_mouth:
I am due to refresh the manual soon and will take more care when generating the file.
You should not get duplicate entries provided the combination of Zone, Room, and Location is unique. If they are unique but you are still getting duplicates, please post your DATA file and a sample YAML with duplicates so that I can investigate further.
Each ā€˜Room’ in the DATA sheet corresponds to one calendar and therefore one temperature. I use a separate calendar per room. The ā€˜Location’ field ensures that each TRV in the same room has a unique name, so there should be no duplicate YAML entries and they are uniquely identified in notification messages. You can use any unique names. I use ā€˜North’, 'South, ā€˜East’ and ā€˜West’, but you can call them 1,2,3,4 or A,B,C,D if you prefer – whatever is meaningful to you to distinguish the TRVs in one room.
I am not sure what function this main thermostat has, or whether it is smart?
Whether you need a zone switch or not depends on your boiler. Some modern boilers have a built-in demand sensor and can be wired to cut off the pump when there is no demand. Older boilers need to be told, often by the old mechanical thermostat.
  • If your boiler does not need a demand (zone) switch AND ā€˜main thermostat’ is the original (dumb) thermostat, then just dial it up to something higher than you will ever set in your calendars (e.g. 30C), otherwise it will limit the actual heating (and this will not be apparent in HA).
  • If it is a smart switch AND your boiler needs a zone switch, AND you do not have any other smart zone switch, then yes, you can use it as a zone valve switch. You should then configure all your TRVs to be in ā€˜Zone 1’.
  • If you have an electric electric zone valve switch that is not smart, AND your boiler needs a zone switch, AND you do not have any other smart zone switch, then you can make it smart by adding a smart switch to operate it and configure that as your zone switch.
  • If it is a smart thermostat then how do you want it to relate to the TRVs? I use the temperature measured by the TRVs to control the radiators; the automation sets the target temperature (the same for all TRVs in a room) and then lets the TRV control the radiator. The central thermostat can be set to anything higher. The automation does not currently have the facility to take into account temperature sensors outside the TRVs (it might be a nice addition, but I would need an algorithm for it). In this case, if your boiler needs a zone switch, AND you do not have any other smart zone switch, then you could define a switch as a ā€˜toggle’ helper and write an automation that sets the smart thermostat to 5C when the switch is off, and 30C when it is on, so making it work like a switch. Then configure the helper as your zone switch.
I hope that helps! If not, please give me more specifics about your boiler, any exiting zone valve or boiler demand switch, and the nature of your ā€˜main thermostat’.
If you find the ideas in this repository useful, don’t forget to Buy Me a Coffee
Thanks Andy I was being a bit dense and sorted it out thanks
Hi Andy, thank you for this. I am testing it now. I’ve managed to get a Heating X2 automation setup and triggering on changes to the thermostat controls on the dashboard.
The issue I’m having is with the calendar. It only triggers maybe 1 in 4 events. Also I’m not getting the #23# temperature copying through from the description.
Is there a reason a calendar event wouldn’t been seen by the automation?
Many thanks!
Andy,
Thanks for all your efforts. I am nearly at the end of updating my heating system and have the smart TRVs installed. The hot water is a typical UK system except that I have two hot water tanks (don’t ask) and I intend to use electric (immersion) heating in the summer (off solar) and via the boiler in the winter. The boiler supplies a manifold and there are zone vales for HW1, HW2 and CH. I have made a box with smart relays to turn on (open) the 3 zone valves and the boiler will run whenever any of them are open.
When I run the mail merge procedure it get sensible text for the ā€œinput_texts.yamlā€ with each room listed as described as well as the two HW tanks with their winter and summer alternatives. However, I can’t understand the results for the ā€œinput_numbers.yamlā€. For example for the lounge, which has three radiators I get three sets of identical text each with a comment heading ā€œ### Lounge heatingā€ with sets of parameters for ā€œmanual temperatureā€ and ā€œrequired temperatureā€ At the bottom of the yaml file there are a lot of similar pairs of parameters but without any text to identify them.
I must admit that I don’t really understand how these helpers are supposed to work and any additonal guidance would be appreciated.
I suspect that my problem is with the mail merge process
I probably should add that when I try to open the word Documents I get a link to ā€œUsers/andrewsymins/Cloud-Drive/Documents/Home Automationā€¦ā€ which Word cannot find. I get the opportunity to provide another data source and I direct it to my Excel file. The process is not as described in your notes but that is probably due to differences in Microsoft software in the last year or so.
Andy,
Further to my request for assistance from a day or two ago, I have been looking further into my issues. The problems appears to be with the input_numbers.yaml file. If I have more than a single radiator (TRV) in a room then the mail merged file will have a matching number of data sets for manual_temperature and required_temperature: one pair for each TRV. Unfortunately, all the pairs have the same heading (based on the room name) and when these are entered into HA I get duplicate key errors. I gather that these are locations to store data from the TRVs and so it seems correct for each TRV to have a pair of locations, but shouldn’t they be individually identified for their associated TRV? Looking at the Excel data sheet it would appear that the ā€œdevice entity nameā€ would fit the bill. I will try to sus out the mail merge process to try to find a solution.
Looking forward to hearing from you.
Hi there, Did you ever resolve this issue? I have the same problem and have made a suggested change but Andy doesn’t seem to be responding at present. If you have a solution please let me know.
Cheers Francis
