Smart home / Main distribution panel smart controller
Hi to all!
I am an electrical engineer and I would like to setup a smart distribution panel controlling a home.
Main concerns:
To control through home assistant and tuya.
To control (and work) online and offline. (if also 4g even better)
To control locally using switches (for lights, shutters etc) which will only give the command (no power through switch - maybe rs485).
Digital & analog inputs to control the circuit and input wind speed, light intensity, temp, humidity etc.
I stumbled on KinCony but they seem very unprofessional and didn’t like their attitude when I contacted them.
Any recommendations on other modules / companies?
Now that I have read a little more in the forum, I don’t know if what I want to do is considered a smart home.
I want a board to control the main distribution board of a home. So a relay board which will be controlled online and offline will turn on and off the whole line (example a light line). It will also be controlled by tooch local switches probably connected on the digital inputs.
Afterwards I want to be able to connect sensors (wond, rain, humidity, temperature etc)
For sure you don’t want anything related to tuya (except if you want to have uncertified chinese crap from unknown manufacturers taking care of your distribution panel).
As an engineer you know that running the whole load of your house through relays 24/7 is quite different case from switching some led lamps.
Whatever you choose, make sure the relays are genuine, made by some known manufacturer (like Omron, Finder etc) and certified in your country. For the “smart” control part you can be more light-hearted.
Τhank you for your reply!
I wouldn’t run the loads from the pcb’s relays but I would use them to run the A1A2 of external relays which then they would power the whole line (mostly lights).
Also would run shutters / rollers and MAYBE some receptacles.
When I say “tuya” you are right about what you say and I would like to be able to control through mobile phone/tablet no matter what app. What do you normally use?
It’s hard to beat Shelly, they are amazing compared to some tuya/sonoff etc.
Totally functional in local network, but offers very good cloud as well.
European company, certified products.
I saw that shelly makes 1-4 channel products. I want to control all light lines from the switchboard…
I have two lines for light’s in my house, many people have one.
My crystal ball is in dishwasher so I don’t see how many you have.
There is also new Shelly X -line, I have not tried yet, but could be worth to look at.
In Europe we use 1 line per room, but I know your crystal ball is still in dishwasher lol.
So when I say light line, I mean:
1st light line is kitchen ceiling.
2nd line is led strip below kitchen cupboards
3rd line is bathroom ceiling
Etc
I live in southern Europe and here the standard is one line per apartment, maybe two for a big house.
Did you have a look at that Shelly X, if I remember well, it has 7 outputs.
Here in Greece we also have 1 MAIN line per house and after the distribution box you break the lines. Normally we have 1 line per 3 or 4 outlets (receptacles) and 1 for lights per room or 2 rooms.
Thanks for the shelly X will give it a look!
For North America, a SPAN load center would do everything you want. It’s also UL listed, uses standard Square D HomeLine breakers, and designed to meet latest building codes. However, it can be very expensive, especially compared to a DIN rail full of Tuya relays.
Home
In Italy, one line for lights, few for outlets and separate lines for heating /ac/ kitchen etc. For two floors, maybe separate set for every floor.
Why? Five separate lines costs less than 50. Also 30x30cm breaker panel is disturbing less interior design… :roll_eyes:
Indeed. Also as you said we have seperate line for oven/cooking range (4mm² normally). Water boiler (10mm²), SOMETIMES seperate for A/C.
So now that we know what we are talking about, my idea was to start seperate lines for EVERYTHING on a new built house. Yes, it would cost more. Yes, the distribution panel will be way bigger (probably twice or more the size of the supposed one). BUT on a newbuilt house, the difference on cost woll be a drop in the ocean and this way you can do whatever you like on each line. Either turning on/off a specofic receptacle of main living room light erc. You get the point.
Ofcourse it is not forbidden by our GR or EU rules, on the contrary it is way better and safer to have each line on it’s dedicated breaker, also way easier to troubleshoot.
I would also like to thanks all of you and Stevemann for the help and guidelines provided! :pray:
You have pro relays to do the HW job so I would look for either Esphome based control or maybe that Shelly X that I haven’t tried yet.
Silly question, for the Shelly’s to work with HA, do I need to reflash them or they work easily through their BT?
If/when a unit breaks down I just need to pair the new unit to the BT or need to do more?
This might sound weird, but I’m not using home assistant. I have fully automated system with many Esphome devices communicating between each other and with Shellys, BLE-devices etc. Shelly has local web server so you can communicate with it through HTTP requests for example.
Anyway, Shelly has full integration.
Does Shelly also support offline, online, 4g, computer and app without cloud?
I wanted to check home assistant green (available in Greece) vs raspberry pi 5 8gb vs any other stable option but the more I read, the more I am getting confused.
On what do you recommend to run HA?
