Smart Home & Tuya IoT - multiple profiles available within Home Assistant?
Can you have access to the identities from Tuya IoT from different profiles & from BOTH Tuya & Smartlife Apps
I ended up with a Smart Home App & Tuya, mainly because I had multiple smart plugs & they seemed to
interfere with other more important devices, alarms etc. (spent weeks trying to fix &gave up)
so I ended up with alarms & few other SOS devices on Tuya & the plugs on smart home. much more reliable, certainly the alarm etc. never misses a beat. The wifi plugs often od & they use to make the alarm unavailable at the same time.
Anyway now have two profiles on IoT
Most work fine on HA but would like to bring in some of the others devices.
I did and a 2nd integration of Tuya, sort of works if reload one & then the others but does seem to fails from time to time, one or the other sets of identities become unavailable.
The profiles are linked in iot.
Can this be done? really don’t want to bring in from tuya to smart or visa versa.
thanks I/A
