I recently bought RM Mini 3 and was looking for how to control Air Conditioner via home assistant as it was working superbly via Broadlink app. So i stumbled upon Smart IR Climate. I went through the documentation as per the instructions created folder in homeassistant config folder and uploaded files there.
However not sure now how to make it work. I have added it as entity using UI Configurator. But clicking on the button doesn’t do anything… Am I doing something wrong? Can’t seem to find anything in the documentation either. There were two codes for Gree AC, and I have tried both.
However I have noticed in services it is showing me only one broadlink. I have read in different posts that when you add multiple broadlink it shows them with their ip to differentiate them in services window.
The Broadlink component has changed in the very last update 0.92. This breaking change has not been documented well yet. It could impact the Smart IR component as well.
Most forum topics you will find about Broadlink will probably contain deprecated formatting. The IP address is no longer part of the service name.
I’m sorry but I don’t know much about the Smart IR component, since I don’t use it myself.
@Emphyrio thank you for your kind response. I guess it is all about waiting till documentation is updated reflecting changes made in 0.92. Thank you once again for the help. Hoping someone else who is using Smart IR component might help
