This led light working on a CB2L what is the BK7231N chip.
Flashing this with OpenBeken WriterV1.6.31
First read the flash.
Then program the new bin file.
After flashing and solder the chip back in the device and conected to the power, you can find the device back in your wifi .
Make the connection and go to 192.168.4.1
Then open the config device and configurated like this.
Return
After testing around go to
Go to Home assistant Discovery
Copy and paste this file after in your config.yaml from (Home Assistant).
Go to MQTT and fill in the Host, User and password.
After go to Wifi and fill in your SSID and password.
The configuration is ready and go now to Home Assistant.
Open your config.yaml and paste the file there.
Save it and re start home assistant.
Now you find in mqtt the device back.
That’s all. Done
Hope you enjoy it.
