Hey
I want lock my Maindoor after 30 minutes
The problem with my simple automation:
what if then door open and close, and the open and close again x10?
The auomation going to run twice and make lock close x10 ?
alias: maindoortest2minute
description: ""
- platform: state
entity_id:
- binary_sensor.0x00158d0004184b4e_contact
to: "on"
condition:
- condition: state
entity_id: binary_sensor.0x00158d0004184b4e_contact
state: "on"
- delay:
hours: 0
minutes: 30
seconds: 0
milliseconds: 0
enabled: true
- device_id: d7c8264e44e76869f1acb9e3fd5f7682
domain: cover
entity_id: cover.lock
type: close
mode: single
What I think you want to do is create an entity in the Helper Templates.
Go to Devices/Services and select Helper tab. Create a Timer helper with your door contact sensor and 30 minute countdown, then use that in your automation to trigger the lights.
The Timer should reset every time the contact sensor goes off so you won’t have repeating automations going off.
Here is an example code I made for my door and my couch light:
alias: Door close light off
description: ""
- platform: event
event_type: timer.finished
event_data:
entity_id: timer.smartlock_timer
- type: not_opened
platform: device
device_id: xxxxxx
entity_id: binary_sensor.u_bolt_pro_z_wave_smart_lock_current_status_of_the_door
domain: binary_sensor
- type: opened
platform: device
device_id: xxxxxxx
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- service: timer.start
duration: "30"
- conditions:
sequence:
- service: timer.cancel
data: {}
- conditions:
sequence:
- type: turn_off
device_id: xxxxxxx
entity_id: light.couch
domain: light
mode: single
You can replace the devices above and timer helper with your entities, although you can do all of this through the UI as well. You can follow this and it should lead you right to where you need to be.
