Smart lock using DC motor with encoder
ah thank you so much, quite clever!
missed somehow the rotary_encoder, thanks so much for explaining! does your lock still work nice?
Or were there any further problems then if I may ask?
I don’t use this anymore because it is quite bulky and doesn’t look so nice, but mostly because the motor is using a lot of gears to have more torque which makes it impossible to turn the key from the other side.
I replaced it with this which is using a stepper motor with 3D printed gears and I’ve been using it for about 3 years and it works perfectly.
Either smart lock you use should run without issues for years, but you need to have a good power supply.
