Smart Locks compatible with home assistant
I have 3 various locks under TTLock and everything works fine.
I have multiple yale locks (assure lock 2, assure lock fingerprint, yrl226) and all works locally using zigbee module via z2m.
Pincode management works too but you need to write automation and script to enable/disable recurring ones or create a one time pin.
Fingerprint still needs to be done via yale lock which is a pain since Yale access requires US as your location.
I’m now looking for mortise lock which makes yale a good candidate too with the ydm7119a or ymf40 but it looks like they dont sell zigbee anymore.
I’ve use ttlock on one of my rooms but it requires internet to work. There’s a solution to control it locally but it’s buggy and the maintainer gave up on it.
I’ve been using Switchbot lock with the hub for last 9-10 months and it is working like a charm with HA.
I’m using the A1 Pro Max Tuya BEL Smart Electronic Door Lock.
It is a great quality lock with competitive price from multiple stores ~$100.
I was able to write my own firmware and load to the lock.
My code is locally and connect natively to HA with AES128 encryption that I added (wrote my own ESPHOME BLE adapter). It is calibrated and operated directly from HA.
BR
Avi
do you mind sharing your code without any personal keys of course
I would love if you can share with us your considerable work.
Like many other members, I’m using this smart lock for a couple of days and struggling to make it work with HA.
Thank you in advance
:pray:t2::pray:t2::pray:t2::pray:t2:
Rafie
Here’s another request to learn more about your firmware. Don’t be afraid to share :slight_smile:
@aviitzhaki
I would absolutely also like to see your great progress for A1 pro lock. How can i participate in testing or reviewing ?
hcjehg
I would love to see your code. I could write up a HowTo if that cold be interesting… ?
Do you have any diagrams or other for the electronics ? Hand drawn ? Which processor is inside the A1 Pro Max ?
Thank you in advance :slight_smile:
Hi! What’s your progress? Can you show a screenshot of the available objects?
