Smart Meter no LED?
I have no idea about Glow integration. If you need bidirectional communication, you need to study the protocol. Hardware is still simple, IR emitter and phototransistor (or IR receiver if modulated). But for counting Wh pulses of the meter, you don’t need anything fancy…
Yea right then thats another option I could test.
Also looking into one of these.
IEC62056-21 IEC1107 Optical Probe with RS232 DB9 Interface Meter Read out Head - AliExpress 30
Might be practical if you need rs232, no sense if you don’t…
Yea ill have a play, at least I have some options now.
Thank you!
Rs232 or Rs485 etc are standards developed to move serial data over long distances. They don’t serve anything else, even if often still used nowadays for short distances for compatibility with old systems.
Going to try this this weekend,
If I am using the S0 port for pulse reading, a pull up or pulldown resistor is required.
Either 10k from GPIO to GND for pull down
Or 1k from GPIO to 3v3 for pull up?
Where is the logic for this? ChatGPT?
No just some of my own research.
http://fun-tech.se/FunTechHouse/ElectricityMeter/
Good!
But why would pulldown be 10 higher than pullup?
Anyway, either way start with 2k, if it doesn’t work go with higher value. Your meter manual didn’t say anything about minimum current of the S0.
