I’m new here and also new in esphome. I found it very useful for making dumb devices smart very easy.
I integrated ESP-12 inside very big and high intensity bathroom lamp with 5 channel LEDs RGB-CW-WW. My goal is to make smart lamp which would be used as ambient lamp at night (from 21:00 to 4:00) and if I press button it will turn on on 100% 4500K from 6:00 to 20:00 and 50% 2700K from 20:00 to 6:00. If the light is turned on another short press turns it off (or ambient during night). Double click turns the lamp on full power. Third function (long press) changes or better said cycles colors (RGB) all on full power.
I already tried but I don’t have experiences with this type of programming. First problem is that I can’t use nested IF conditions. I tried with lambda but I always get some errors. I don’t even know how to check the state of “wc_light”. I would appreciate some help with this project.
time:
- platform: homeassistant
binary_sensor:
- platform: gpio
pin:
number: GPIO02
#mode: INPUT_PULLUP
inverted: true
on_multi_click:
- timing:
- ON for at most 1s
- OFF for at most 1s
- ON for at most 1s
- OFF for at least 0.2s
then:
- logger.log: "Double Clicked"
- light.turn_on:
brightness: 100%
color_temperature: 4500K
- timing:
- ON for at least 1.5s
then:
- logger.log: "Long Press"
- light.turn_off: wc_light
- timing:
- ON for at most 1s
- OFF for at least 0.3s
then:
- logger.log: "Single Short Clicked"
- if:
condition:
- light.is_on: wc_light
#lambda: 'return id(esptime).now().second >= 30;'
then:
else:
- if:
condition:
- lambda: 'return id(esptime).now().hour >= 20 || id(esptime).now().hour <= 6;'
then:
lambda: |-
if(return id(wc_light).current_values.get_state()){
auto call = id(wc_light).make_call();
call.set_state(false);
call.perform();
} else {
static int color_temp = 370;
static int transition = 3000;
call.set_state(true);
call.set_color_temperature(color_temp);
call.set_transition_length(transition);
call.set_brightness(0.5);
call.perform();
else:
lambda: |-
static int color_temp = 255;
static int transition = 1000;
call.set_brightness(1.0);
call.perform();
light:
- platform: rgbww
red: pwm_red
green: pwm_green
blue: pwm_blue
cold_white: pwm_cw
warm_white: pwm_ww
cold_white_color_temperature: 6000 K
warm_white_color_temperature: 2700 K
constant_brightness: false
color_interlock: true
output:
- platform: esp8266_pwm
pin: GPIO12
frequency: 800 Hz
pin: GPIO14
frequency: 800 Hz
pin: GPIO04
frequency: 800 Hz
pin: GPIO13
frequency: 1000 Hz
max_power: 100%
pin: GPIO05
frequency: 1000 Hz
max_power: 100%
