Smart Plug and Smart Switch List
I am creating a list of all the compatible smart plugs and switches natively supported by Home Assistant. The listing of HA components is a useful starting point for my research. However, it doesn’t state other features, such as need for external additional hub, current rating, price, etc.
The following image is an example of my current research so far. Current research is US only, but could be extended easily
If I create a list for the community to review, what is the best format to post it?
Or, if this is can be community editable, where should I put it?
TallJ
Have you seen this?
https://www.hadevices.com
No Sonoff?
I would like to see this made permanent. If you have an account on GitHub you could just post it there as a spreadsheet or CSV, and let others contribute to it.
Why limit it to plugs and switches? The format would apply to lights, cameras and sensors as well.
Missing columns:
  • Protocol (IP, Z-Wave, X-Bee, Bluetooth)
  • Home Assistant component.
  • possibly a link to any tutorial page.
Add your info to hadevices.com - no need to reinvent the wheel.
Or put it on github.
Great info. I was not aware of the hadevices.com resource and website.
Can we suggest devices to HADevices? It seemed to be missing a few things.
You mean at the top of the web page where it says “Add a Device”?
My bad, was on mobile.
hello all,
has anyone had experience with a 4+4 power+usb switch like the following?
Effectively, the question is if something is known to integrate well and control all ports -power and usb- as distinct (and hopefully not be too inflated in price)
tia,
F.
p.s. the hadevices.com is interesting, however it is heavily biased for US plugs, so I’d rather see a solution with schuko or europlug or even swiss plug compatibility.
Hello fgeorgatos and Welcome to the Forum! I have just read in the German description that the sockets individually and the USB plug are switched together. Have a similar power strip and there it is so. My power strip is shown as 5 switches in HA (4x 230V + 1x USB). I suspect that this is a Tuya power strip …
The price is okay, I would say …
Can you share config from HA? Is it discoverable or you need some integration or configuration.yaml entry?
Has anyone had success with smart light bulb sockets that work and integrate with HA? I have two lights in our garage that are wonderfully bright 3 panel LED lights and would love to have the ability to turn them on and off, but they are not smart home or wifi enabled devices.
Is it just me have issue submitting to HADevices?
I also don’t find US stuff too useful and I am in Australia, so trying to add the AU/NZ type of devices
I can only suggest what I have use so far and that is Wiz Smart Plugs https://www.wizconnected.com/ but that would mean it would have to be terminated to a plug of some sort.
I can not recommend as have not used them at all, but something like https://www.amazon.com.au/Wireless-Intelligent-Compatible-Assistant-Function/dp/B08T1R7MCQ
