What are the best practices in HA for displaying the state of my Shelly Plug S smart plug?.
I use a smart plug on my washing machine that has a soft button so the power state in HA is always powered on.
Are there other options to visualize when the washing machine is on/of by example monitoring the power consumption?
Thx in advance for some advice.
Sorry, I don’t fully understand you. How have you integrated your Shelly Plug S?
I am also using the Shelly Plug S on my washing machine and tumble dryer using the Home Assistant official integration and as the Shelly 1 PM it shows it’s relay state correctly within home assistant. I can toggle the relay using the Home Assistant interface, the Shelly app, or the button on the Shelly Plug S itself. The state is always reflected correctly.
I use also the official Shelly integration in HA and this works fine. In my case the smart plug need always to be powered on, So the switch state of the smart plug is always on.in the frontend of HA and the Shelly app. When I use the washing machine I need to push on the soft button of the machine to start.
So my question is about the visulization of the state of the washing machine in the frontend of HA.
Then you would need to monitor the power consumption. Do you see a significant change in power consumption between off and on?
If the machine is running you will definitely see a large power increase.
Ah, I understand. Inspired by W3MA I created an input_select with the states of the laundry cycle (Off, Idle, Running, Done), which is set by automations. This input_select is then read by a templated sensor, that shows the current state in Lovelace.
The automations need to be tweaked according to your expierience. For example I noticed, that my tumble dryer remains powered, with little power consumption, after it is done. The washing machine however completly shuts off, so there was not indication if it was in the state ‘Done’, or has already been emptied and is again in ‘Idle’ state. Due to this reason, I added a Xiaomi Aqara Door Sensor on the waching machines door, so I know if it has been emptied, or not and also the power usage thresholds may vary.
Sensor
sensors:
washer_status:
friendly_name: "Waschmaschine"
icon_template: >-
{% if is_state("sensor.washer_status", "Running") %}
mdi:washing-machine
{% else %}
mdi:washing-machine-off
{% endif %}
value_template: '{{ states.input_select.washer_status_dropdown.state }}'
attribute_templates:
Counter: >-
{{ states('counter.washing_cycles') }}
Power: >-
{{ states('sensor.washer_power') }}
Energy: >-
{{ states('sensor.washer_energy') }}
Last Changed: >-
{{ relative_time(states.sensor.washer_status.last_changed) }}
dryer_status:
friendly_name: "Trockner"
icon_template: >-
{% if is_state("sensor.dryer_status", "Running") %}
mdi:tumble-dryer
{% else %}
mdi:tumble-dryer-off
{% endif %}
value_template: '{{ states.input_select.dryer_status_dropdown.state }}'
Counter: >-
{{ states('counter.dryer_cycles') }}
Power: >-
{{ states('sensor.dryer_power') }}
Energy: >-
{{ states('sensor.dryer_energy') }}
Last Changed: >-
{{ relative_time(states.sensor.dryer_status.last_changed) }}
Automations
## Washing machine / tumble dryer powered off
- alias: Laundry - powered off
#When power plug is turned off
- platform: state
entity_id:
- switch.washer
- switch.dryer
to: 'off'
mode: parallel
- service: input_select.select_option
data_template:
entity_id: >
{% if trigger.entity_id == 'switch.washer' %}
{% else %}
{% endif %}
option: 'Off'
## Washing machine / tumble dryer idle
- alias: Laundry - Idle
#Initial state, when power plugs are turned on
- platform: state
entity_id:
- switch.washer
- switch.dryer
to: 'on'
#Return to idle, when washing machine is emptied
- platform: state
entity_id: binary_sensor.washing_machine_door
to: 'on' #'Open'
#Tumble dryer is manually set to 'Off', when emptied.
#When turned off, power consumption drops to 0W.
value_template: "{% if states.sensor.dryer_power.state | float == 0.0 %} true {% endif %}"
mode: parallel
condition:
{{( trigger.to_state.entity_id == 'switch.washer' )
or
( trigger.to_state.entity_id == 'switch.dryer' )
or
( trigger.to_state.entity_id == 'binary_sensor.washing_machine_door' and
states('input_select.washer_status_dropdown') == 'Done' )
or
( trigger.to_state.entity_id == 'sensor.dryer_power' and
states('input_select.dryer_status_dropdown') == 'Done' )}}
data_template:
entity_id: >
{% if trigger.entity_id in ['switch.washer', 'binary_sensor.washing_machine_door'] %}
{% else %}
{% endif %}
option: 'Idle'
## Laundry process started
- alias: Laundry - process started
#Power consumption threshold to sense washing machine is running
value_template: "{% if states.sensor.washer_power.state | float > 5.0 %} true {% endif %}"
#Power consumption threshold to sense tumble dryer is running
value_template: "{% if states.sensor.dryer_power.state | float > 5.0 %} true {% endif %}"
mode: parallel
condition:
{{( trigger.to_state.entity_id == 'sensor.washer_power' and
states('input_select.washer_status_dropdown') == 'Idle' )
or
states('input_select.dryer_status_dropdown') == 'Idle' )}}
data_template:
entity_id: >
{% if trigger.entity_id == 'sensor.washer_power' %}
{% else %}
{% endif %}
option: 'Running'
## Laundry process finished
- alias: Laundry - process finished
#Power consumption threshold to sense washing machine is done
value_template: "{% if states.sensor.washer_power.state | float <= 4.0 %} true {% endif %}"
value_template: "{% if states.sensor.dryer_power.state | float <= 5.0 %} true {% endif %}"
mode: parallel
condition:
states('input_select.washer_status_dropdown') == 'Running' )
or
states('input_select.dryer_status_dropdown') == 'Running' )}}
data_template:
entity_id: >
{% else %}
{% endif %}
option: 'Done'
- service: counter.increment
data_template:
entity_id: >
{% else %}
counter.drying_cycles
{% endif %}
Thx a lot for this explanation! I will try this.
A bit late of course, but for the benefit of others - how about this: How To Monitor Your Washing Machine in Home Assistant - YouTube
