Smart plug
I searching for a Smart plug where i can monitor the power consumption like
the shelly plug or the fibaro Zwave . I see a lot of different models/brands
but are there other brands which can also monitor the consumption and can be easily be integrated into HA?
Zooz has great plugs. I use their high voltage ones for things like portal heaters.
Zooz Z-Wave Plus Power Switch ZEN15 for 110V AC Units, Sump Pumps, Humidifiers, and More https://www.amazon.com/dp/B07578W7KY/ref=cm_sw_r_cp_api_glt_i_G546VS0YZPBYM2TAGQDB
Your options do depend on where in the world you are, since there’s not yet a single unified electrical standard.
Frenck, one of the key people in HA added this to his website and I just ordered 4 of them based on that …but I have no feedback on them in particular
Calibrating an ESPHome flashed power plug » Frenck.dev
thx, i will check these
i used the Shelly Plug S but it only go’s to 2500W, and my washing machine hit’s that limit so its stopping all the time, are there any plugs that are compatible with home assistant that can have more W
I saw shelly has a version Shelly Plug that go’s to 3500 but they are sold out everywhere
For the dutch People i found one that is on zigbee and works in home assistant:
i had the Fibaro Wall Plug Zwave, that worked fine 2500W . But after 2year, it did not work anymore
So im searching for a other brand , maybe on wifi and not on zwave anymore
Shelly plug en shelly plug S bolth on wifi are maybe a good solution?
there are also some smart plugs , which are running on tuya, like SMARTIFY
for i me do not want to have an extra application running special for the smart plug.
So Zware( i have already a zwave stick) or Wifi ( i have already Shelly)
But how can you check what application it uses on wifi . like tuya or etc …
I’m on North American split phase power.
I use TP Link for several in my house. I also use a Shelly 1PM wired behind a standard outlet to make it smart and monitor power consumption.
