Smart Relays
Dear,
I would like to have some input about external integration with some “Smart” relays.
I looking for interaction with external captor like Alarm, Water detection. These module usually returns an analogic output 0-10v other needs analogic input 0-10v to trigger some action
Do you have some reference for such external module that could be directly connected to Hass.io
I found https://konnected.io/ but seems focusing on Alarm system
Thank you
When you say “directly connected” do you mean not through the use of Z-Wave or Insteon? If so then I don’t know, but if Z-Wave and/or Insteon is acceptable then there are all sorts of relays you can get. RelayLinc (Insteon) and MIMOlite (Z-Wave) come to mind.
Thank you !
MIMOlite seems perfect. The only bad point is that there are not a lot of input/output. I’ve seen that a new module is available but still limited to 2 output / input
