I have just startet using home assistant, and I wanted a smart screen for my home so I setup a iPad in the center of the home, but quickly found out it was using the battery in no time running kiosk mode with screensaver. So I was wondering if anyone else is doing the same as me and what have you done with your iPad/tablet
Connect it to a power source? It probably limits the placement a bit though.
I have considered that, I was only thinking about the fire hazards with the battery overheating if it plugged in 24/7
Surely an Ipad has the ability to charge a battery without setting fire to itself?
Anyhow control the charging to 80% using an app, you can do this on Android so must be able to do it on apple. Or use a smart plug to do it. Most here have been running this sort of setup for years without issues.
Newer ipads can set a max battery limit, yes.
