Smart Servos Smarter - ESPHome style
While I will admit that smart servos are a niche for those that cannot code their own PWM + rotary encoder + PID. It is even harder for those that cannot code their own motion control algorithms (RPM, ac/de-celeration, hold stiffness, etc); which is me.
With the help of @phillip1, I think there is some really useful code to share that brings Lynxmotion LSS smart servos into the ESPHome world. And while not entirely exhaustive, it is a solid foundation to add any missing feature from the communication protocol.
Why a Smart Servo?
Well let’s cover the benefits;
  • far simpler to deploy with existing libraries
  • can be daisy chained
  • highly configurable out of the box
Now I understand that they cost 10X the price of analogue servo. That’s what sales are for!
Lynxmotion Servo Control
The LSS Communication Protocol is actually quite ESPHome friendly by using simple text parsing and no CRC/checksum’s. We can not only control the direction, speed and holding power; but have live feedback of current values! This is benefitial to ensure that HA is in sync w/ the servo’s current state.
In addition to “knowning state”, you can control behavior beyond just movement. You can control whether the server “holds” or resists outside forces. Or if it should go “limp” and allow free movement. All of a sudden, your servo isn’t controlling something, it is measuring!
With a single servo up and running, you’ll want to add a second. This is where the below code becomes more useful. As long as you follow the naming convention, all state will be captured without additional coding.
YAML Naming Convention
Prefix: servo# where # is an identifier digit from 1 to 9. ID 0 is reserved as a default for all servos and should be avoided
Name: _NAME where NAME is the description matching a configuration parameter including;
  • led
  • gyre
  • state
  • degree
  • degree_per_second
  • angular_acceleration
  • angular_deceleration
  • hold_mode
  • limp_mode
The Code
The .h
This solution leverages a Custom UART Text Sensor with one small tweak. Returning on the ‘*’ character which is indicative of a response from a servo.
    if (readch > 0) {
      switch (readch) {
        case '\n': // Ignore new-lines
          break;
        case '\r': // Return on CR
          rpos = pos;
          pos = 0;  // Reset position index ready for next time
          return rpos;
        case '*': // Return on LSS servo response
          rpos = pos;
          return rpos;
        default:
          if (pos < len-1) {
            buffer[pos++] = readch;
            buffer[pos] = 0;
YAML
I have included a two (2) servo example. By following the naming convention you can easily add 3-9 servos with no added C++ lambda’s necessary to capture state info.
esphome:
  includes:
    - uart_read_line_sensor_lss.h
logger:
  logs:
    text_sensor: INFO
switch:
    optimistic: true
    assumed_state : OFF
    optimistic: true
    assumed_state : ON
    turn_on_action:
      - uart.write:
          data: "#1CG1\r"
    turn_off_action:
      - uart.write:
          data: "#1CG-1\r"
    optimistic: true
    assumed_state : ON
    turn_on_action:
      - uart.write:
          data: "#2CG1\r"
    turn_off_action:
      - uart.write:
          data: "#2CG-1\r"
    optimistic: true
    assumed_state : ON
    turn_on_action:
      - uart.write:
          data: "#1H\r"
    turn_off_action:
      - uart.write:
          data: "#1L\r"
    optimistic: true
    assumed_state : ON
    turn_on_action:
      - uart.write:
          data: "#2H\r"
    turn_off_action:
      - uart.write:
          data: "#2L\r"
    optimistic: true
    assumed_state : true
    turn_on_action:
      - uart.write:
          data: "#1L\r"
    turn_off_action:
      - uart.write:
          data: "#1H\r"
    optimistic: true
    turn_on_action:
      - uart.write:
          data: "#2L\r"
    turn_off_action:
      - uart.write:
          data: "#2H\r"
    optimistic: true
    turn_on_action:
      - uart.write:
          data: "#1CLED5\r"
      - delay: 500ms
      - uart.write:
          data: "#1QLED\r"
    turn_off_action:
      - uart.write:
          data: "#1CLED0\r"
      - delay: 500ms
      - uart.write:
          data: "#1QLED\r"
    optimistic: true
    turn_on_action:
      - uart.write:
          data: "#2CLED6\r"
      - delay: 500ms
      - uart.write:
          data: "#2QLED\r"
    turn_off_action:
      - uart.write:
          data: "#2CLED0\r"
      - delay: 500ms
      - uart.write:
          data: "#2QLED\r"
button:
    on_press:
      - uart.write:
          data: "#1RESET\r"
    on_press:
      - uart.write:
          data: "#2RESET\r"
uart:
  - id: uart_bus
    tx_pin: GPIO18
    rx_pin: GPIO5
    baud_rate: 115200
number:
    step: 1
    min_value: 1
    max_value: 600
    optimistic: true
    restore_value: true
    initial_value: 360
    mode: box
    step: 1
    min_value: 1
    max_value: 600
    optimistic: true
    restore_value: true
    initial_value: 360
    mode: box
    step: 0.1
    min_value: -90
    max_value: 90
    mode: box
    set_action:
      - uart.write:
          data: !lambda
            std::string D = "#1D" + to_string(int(x*10)) + "SD" + to_string(int(id(servo1_degree_per_second).state*10)) +"\r";
            return std::vector<uint8_t>(D.begin(), D.end());
      - delay: 1s
      - uart.write:
          data: "#1QD\r"
    step: 0.1
    min_value: -33
    max_value: 110
    mode: box
    set_action:
      - uart.write:
          data: !lambda
            std::string D = "#2D" + to_string(int(x*10)) + "SD" + to_string(int(id(servo2_degree_per_second).state*10)) +"\r";
      - delay: 1s
      - uart.write:
          data: "#2QD\r"
    step: 1
    min_value: 1
    max_value: 360
    # optimistic: true
    restore_value: true
    initial_value: 100
    mode: box
    set_action:
      - uart.write:
          data: !lambda
            std::string CAA = "#1CAA" + to_string(int(x*10)) +"\r";
            return std::vector<uint8_t>(CAA.begin(), CAA.end());
      - delay: 1s
      - uart.write:
          data: "#1QAA\r"
    step: 1
    min_value: 1
    max_value: 360
    # optimistic: true
    restore_value: true
    initial_value: 100
    mode: box
    set_action:
      - uart.write:
          data: !lambda
            std::string CAA = "#2CAA" + to_string(int(x*10)) +"\r";
      - delay: 1s
      - uart.write:
          data: "#2QAA\r"
    step: 1
    min_value: 1
    max_value: 360
    # optimistic: true
    restore_value: true
    initial_value: 100
    mode: box
    set_action:
      - uart.write:
          data: !lambda
            std::string CAD = "#1CAD" + to_string(int(x*10)) +"\r";
            return std::vector<uint8_t>(CAD.begin(), CAD.end());
      - delay: 1s
      - uart.write:
          data: "#1QAD\r"
    step: 1
    min_value: 1
    max_value: 360
    # optimistic: true
    restore_value: true
    initial_value: 100
    mode: box
    set_action:
      - uart.write:
          data: !lambda
            std::string CAD = "#2CAD" + to_string(int(x*10)) +"\r";
      - delay: 1s
      - uart.write:
          data: "#2QAD\r"
interval:
  - interval: 1s
    then:
      - uart.write:
          data: "#1Q\r"
      - uart.write:
           data: "#2Q\r"
      - if:
          condition:
            switch.is_on: servo1_limp_mode
          then:
            - uart.write:
                data: "#1QD\r"
      - if:
          condition:
            switch.is_on: servo2_limp_mode
          then:
            - uart.write:
                data: "#2QD\r"
text_sensor:
    # internal: true
    # internal: true
  - platform: custom
    lambda: |-
      auto my_custom_sensor = new UartReadLineSensor(id(uart_bus));
      App.register_component(my_custom_sensor);
      return {my_custom_sensor};
    text_sensors:
      internal: true
      on_value:
        lambda: |-
          auto publishNumber = [](std::string idx, std::string sensor, float resp) {
            auto sens = App.get_numbers();
            for(int i = 0; i < sens.size(); i++) {
              auto name = sens[i]->get_name();
              auto servo = "servo" + to_string(idx);
              if(name.size() > 7 && name.substr(0, 6) == servo) {
                if(name.substr(7) == sensor) {
                  sens[i]->publish_state(resp);
          auto publishSwitch = [](std::string idx, std::string sensor, int state) {
            auto sens = App.get_switches();
                  sens[i]->publish_state(state);
          auto publishTextSensor = [](std::string idx, std::string sensor, std::string stringstate) {
            auto sens = App.get_text_sensors();
                  sens[i]->publish_state(stringstate);
          auto ss = [](int pos, int len) {
            std::string line = id(servo_readline).state;
            return line.substr(pos, len);
          std::string sid = ss(0,1);
          // Degree
          if (ss(1,3) == "QD-") {
              float QDR = parse_number<float>(ss(3,5)).value();
              publishNumber(sid,"degree",(QDR/10));
          } else if (ss(1,2) == "QD") {
              float QDR = parse_number<float>(ss(3,4)).value();
          // Angular Acceleration
          else if (ss(1,3) == "QAA") {
              float QAAR = parse_number<float>(ss(4,4)).value();
              publishNumber(sid,"angular_acceleration",(QAAR/10));
          // Angular Deceleration
          else if (ss(1,2) == "QAD") {
              float QADR = parse_number<float>(ss(4,4)).value();
              publishNumber(sid,"angular_deceleration",(QADR/10));
          // LED
          else if (ss(1,4) == "QLED") {
              publishSwitch(sid,"led",(int)(ss(5,1) != "0"));
          // Unknown Mode
          else if (ss(1,2) == "Q0") {
              publishTextSensor(sid,"state","Unknown");
          // Limp Mode
          else if (ss(1,2) == "Q1") {
              publishSwitch(sid,"hold_mode",0);
              publishSwitch(sid,"limp_mode",1);
              publishTextSensor(sid,"state","Limp");
          // Hold Mode
          else if (ss(1,2) == "Q6") {
              publishSwitch(sid,"hold_mode",1);
              publishSwitch(sid,"limp_mode",0);
              publishTextSensor(sid,"state","Hold");
          // Stuck Mode
          else if (ss(1,2) == "Q8") {
              publishTextSensor(sid,"state","Stuck");
          // Blocked Mode
          else if (ss(1,2) == "Q9") {
              publishTextSensor(sid,"state","Blocked");
          // Safe Mode
          else if (ss(1,3) == "Q10") {
              publishTextSensor(sid,"state","SafeMode");
          // Gyre Counter-Clockwise
          else if (ss(1,3) == "QG-") {
              publishSwitch(sid,"gyre",0);
          // Gyre Clockwise
          else if (ss(1,3) == "QG1") {
              publishSwitch(sid,"gyre",1);
