Smart socket with wrong data
hello,
I’ve problem with wrong values at power socket.
Current is A. In my opinion should mA.
Finally the sum of energy consumption is miscalculated.
How can I change current? It should be divided by 1000 I guess
Device:
TS011F
_TZ3000_okaz9tjs
Quirk: zhaquirks.tuya.ts011f_plug.Plug_v3
logs:
  "home_assistant": {
    "installation_type": "Home Assistant Container",
    "version": "2024.1.2",
    "dev": false,
    "hassio": false,
    "virtualenv": false,
    "python_version": "3.11.6",
    "docker": true,
    "arch": "x86_64",
    "timezone": "Europe/Warsaw",
    "os_name": "Linux",
    "os_version": "5.15.0-89-generic",
    "run_as_root": true
  "custom_components": {
    "ssh": {
      "version": "0.1.5",
      "requirements": [
        "pexpect==4.6.0"
    "ecovent_v2": {
      "version": "0.9.2",
      "requirements": [
        "pyEcoventV2==0.9.15"
    "config_editor": {
      "version": "4.3",
      "requirements": []
    "esp_wd": {
      "version": "0.0.1",
      "requirements": []
    "scheduler": {
      "version": "v0.0.0",
      "requirements": []
    "localtuya": {
      "version": "5.2.1",
      "requirements": []
    "burze_dzis_net": {
      "version": "v2.0.0",
      "requirements": [
        "suds"
    "hacs": {
      "version": "1.33.0",
      "requirements": [
        "aiogithubapi>=22.10.1"
    "smartthings_soundbar": {
      "version": "v1.0.2",
      "requirements": []
    "hydro_imgw": {
      "version": "v1.0.4",
      "requirements": [
        "requests"
    "dahua": {
      "version": "0.5.0",
      "requirements": []
    "dbuezas_eq3btsmart": {
      "version": "6.2.1",
      "requirements": [
        "construct==2.10.56"
    "adaptive_lighting": {
      "version": "1.20.0",
      "requirements": [
        "ulid-transform"
    "google_home": {
      "version": "1.11.0",
      "requirements": [
        "glocaltokens==0.7.0"
    "imou_life": {
      "version": "1.0.14",
      "requirements": [
        "imouapi==1.0.14"
    "sonoff": {
      "version": "3.5.4",
      "requirements": [
        "pycryptodome>=3.6.6"
    "garmin_connect": {
      "version": "0.2.19",
      "requirements": [
        "garminconnect==0.2.12",
        "tzlocal"
    "asusrouter": {
      "version": "0.28.0",
      "requirements": [
        "asusrouter==1.6.1"
    "gree": {
      "version": "2.3.1",
      "requirements": [
        "pycryptodome"
    "meross_lan": {
      "version": "4.5.2",
      "requirements": []
    "ble_monitor": {
      "version": "12.8.1",
      "requirements": [
        "pycryptodomex>=3.18.0",
        "janus>=1.0.0",
        "aioblescan>=0.2.14",
        "btsocket>=0.2.0",
        "pyric>=0.1.6.3"
    "powercalc": {
      "version": "v1.9.15",
      "requirements": [
        "numpy>=1.21.1"
  "integration_manifest": {
    "domain": "zha",
    "name": "Zigbee Home Automation",
    "after_dependencies": [
      "onboarding",
      "usb"
    "codeowners": [
      "@dmulcahey",
      "@adminiuga",
      "@puddly",
      "@TheJulianJES"
    "config_flow": true,
    "dependencies": [
      "file_upload"
    "documentation": "https://www.home-assistant.io/integrations/zha",
    "iot_class": "local_polling",
    "loggers": [
      "aiosqlite",
      "bellows",
      "crccheck",
      "pure_pcapy3",
      "zhaquirks",
      "zigpy",
      "zigpy_deconz",
      "zigpy_xbee",
      "zigpy_zigate",
      "zigpy_znp",
      "universal_silabs_flasher"
    "requirements": [
      "bellows==0.37.6",
      "pyserial==3.5",
      "pyserial-asyncio==0.6",
      "zha-quirks==0.0.109",
      "zigpy-deconz==0.22.4",
      "zigpy==0.60.4",
      "zigpy-xbee==0.20.1",
      "zigpy-zigate==0.12.0",
      "zigpy-znp==0.12.1",
      "universal-silabs-flasher==0.0.15",
      "pyserial-asyncio-fast==0.11"
    "usb": [
        "vid": "10C4",
        "pid": "EA60",
        "description": "*2652*",
        "known_devices": [
          "slae.sh cc2652rb stick"
        "vid": "1A86",
        "pid": "55D4",
        "description": "*sonoff*plus*",
        "known_devices": [
          "sonoff zigbee dongle plus v2"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "sonoff zigbee dongle plus"
        "vid": "10C4",
        "pid": "EA60",
        "description": "*tubeszb*",
        "known_devices": [
          "TubesZB Coordinator"
        "vid": "1A86",
        "pid": "7523",
        "known_devices": [
        "vid": "1A86",
        "pid": "7523",
        "description": "*zigstar*",
        "known_devices": [
          "ZigStar Coordinators"
        "vid": "1CF1",
        "pid": "0030",
        "description": "*conbee*",
        "known_devices": [
          "Conbee II"
        "vid": "0403",
        "pid": "6015",
        "known_devices": [
          "Conbee III"
        "vid": "10C4",
        "pid": "8A2A",
        "description": "*zigbee*",
        "known_devices": [
          "Nortek HUSBZB-1"
        "vid": "0403",
        "pid": "6015",
        "description": "*zigate*",
        "known_devices": [
          "ZiGate+"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "ZiGate"
        "vid": "10C4",
        "pid": "8B34",
        "description": "*bv 2010/10*",
        "known_devices": [
          "Bitron Video AV2010/10"
    "zeroconf": [
        "type": "_esphomelib._tcp.local.",
        "name": "tube*"
        "type": "_zigate-zigbee-gateway._tcp.local.",
        "name": "*zigate*"
        "type": "_zigstar_gw._tcp.local.",
        "name": "*zigstar*"
        "type": "_uzg-01._tcp.local.",
        "name": "uzg-01*"
        "type": "_slzb-06._tcp.local.",
        "name": "slzb-06*"
    "is_built_in": true
  "data": {
    "ieee": "**REDACTED**",
    "nwk": 50591,
    "manufacturer": "_TZ3000_okaz9tjs",
    "model": "TS011F",
    "name": "_TZ3000_okaz9tjs TS011F",
    "quirk_applied": false,
    "quirk_class": "zigpy.device.Device",
    "quirk_id": null,
    "manufacturer_code": 4660,
    "power_source": "Mains",
    "lqi": 255,
    "rssi": -61,
    "last_seen": "2024-01-10T12:27:02",
    "available": true,
    "device_type": "Router",
    "signature": {
      "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.FullFunctionDevice|MainsPowered|RxOnWhenIdle|AllocateAddress: 142>, manufacturer_code=4660, maximum_buffer_size=108, maximum_incoming_transfer_size=0, server_mask=11264, maximum_outgoing_transfer_size=0, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
      "endpoints": {
        "1": {
          "profile_id": "0x0104",
          "device_type": "0x0100",
          "input_clusters": [
            "0x0000",
            "0x0003",
            "0x0004",
            "0x0005",
            "0x0006",
            "0x000a",
            "0x0702",
            "0x0b04",
            "0x1000",
            "0xe000",
            "0xe001"
          "output_clusters": []
      "model": "TS011F"
    "active_coordinator": false,
    "entities": [
        "entity_id": "sensor.gniazdo_tv_sypialnia_current",
        "entity_id": "button.gniazdo_tv_sypialnia_identify",
        "entity_id": "light.gniazdo_tv_sypialnia_light",
        "entity_id": "sensor.gniazdo_tv_sypialnia_power",
        "entity_id": "select.gniazdo_tv_sypialnia_start_up_behavior",
        "entity_id": "sensor.gniazdo_tv_sypialnia_summation_delivered",
        "entity_id": "sensor.gniazdo_tv_sypialnia_voltage",
    "neighbors": [
        "rx_on_when_idle": "On",
        "relationship": "Parent",
        "extended_pan_id": "**REDACTED**",
        "nwk": "0x03DF",
        "permit_joining": "NotAccepting",
        "depth": "1",
        "lqi": "55"
        "relationship": "Sibling",
        "nwk": "0x7F1F",
        "depth": "1",
        "lqi": "111"
        "device_type": "Coordinator",
        "nwk": "0x0000",
        "permit_joining": "Accepting",
        "depth": "0",
        "lqi": "1"
        "nwk": "0x40D7",
        "depth": "1",
        "lqi": "47"
        "nwk": "0x7F13",
        "depth": "1",
        "lqi": "117"
        "nwk": "0x9DE7",
        "depth": "1",
        "lqi": "111"
        "nwk": "0x8077",
        "depth": "2",
        "lqi": "117"
        "nwk": "0x2E2C",
        "depth": "2",
        "lqi": "117"
        "nwk": "0xEC7B",
        "depth": "3",
        "lqi": "111"
        "nwk": "0xFED2",
        "depth": "0",
        "lqi": "47"
    "routes": [],
    "endpoint_names": [
        "name": "ON_OFF_LIGHT"
    "user_given_name": "gniazdo-tv_sypialnia",
    "device_reg_id": "ebfcd05476103eaefed92e445171fbf2",
    "area_id": "sypialnia",
    "cluster_details": {
      "1": {
        "device_type": {
          "name": "ON_OFF_LIGHT",
          "id": 256
        "profile_id": 260,
        "in_clusters": {
          "0x0000": {
            "endpoint_attribute": "basic",
            "attributes": {
              "0x0004": {
                "attribute_name": "manufacturer",
                "value": "_TZ3000_okaz9tjs"
              "0x0005": {
                "attribute_name": "model",
                "value": "TS011F"
            "unsupported_attributes": {}
          "0x0006": {
            "endpoint_attribute": "on_off",
            "attributes": {
              "0x4002": {
                "attribute_name": "off_wait_time",
                "value": 0
              "0x0000": {
                "attribute_name": "on_off",
                "value": 1
              "0x4001": {
                "attribute_name": "on_time",
                "value": 0
              "0x4003": {
                "attribute_name": "start_up_on_off",
                "value": 255
          "0x0003": {
            "endpoint_attribute": "identify",
            "attributes": {},
          "0x0004": {
            "endpoint_attribute": "groups",
            "attributes": {},
          "0x0005": {
            "endpoint_attribute": "scenes",
            "attributes": {},
          "0x1000": {
            "endpoint_attribute": "lightlink",
            "attributes": {},
          "0x000a": {
            "endpoint_attribute": "time",
            "attributes": {},
          "0xe001": {
            "endpoint_attribute": null,
            "attributes": {},
          "0xe000": {
            "attributes": {},
          "0x0702": {
            "endpoint_attribute": "smartenergy_metering",
            "attributes": {
              "0x0000": {
                "attribute_name": "current_summ_delivered",
                "value": 26
              "0x0302": {
                "attribute_name": "divisor",
                "value": 1280
              "0x0306": {
                "attribute_name": "metering_device_type",
                "value": 0
              "0x0301": {
                "attribute_name": "multiplier",
                "value": 1280
              "0x0200": {
                "attribute_name": "status",
                "value": 0
              "0x0303": {
                "attribute_name": "summation_formatting",
                "value": 0
              "0x0300": {
                "attribute_name": "unit_of_measure",
                "value": 0
              "0x0400": {
                "attribute_name": "instantaneous_demand"
              "0x0100": {
                "attribute_name": "current_tier1_summ_delivered"
              "0x0102": {
                "attribute_name": "current_tier2_summ_delivered"
              "0x0104": {
                "attribute_name": "current_tier3_summ_delivered"
              "0x0106": {
                "attribute_name": "current_tier4_summ_delivered"
              "0x0108": {
                "attribute_name": "current_tier5_summ_delivered"
              "0x010a": {
                "attribute_name": "current_tier6_summ_delivered"
              "0x0304": {
                "attribute_name": "demand_formatting"
          "0x0b04": {
            "endpoint_attribute": "electrical_measurement",
            "attributes": {
              "0x0603": {
                "attribute_name": "ac_current_divisor",
                "value": 1
              "0x0602": {
                "attribute_name": "ac_current_multiplier",
                "value": 1
              "0x0605": {
                "attribute_name": "ac_power_divisor",
                "value": 1
              "0x0604": {
                "attribute_name": "ac_power_multiplier",
                "value": 1
              "0x0601": {
                "attribute_name": "ac_voltage_divisor",
                "value": 1
              "0x0600": {
                "attribute_name": "ac_voltage_multiplier",
                "value": 1
              "0x050b": {
                "attribute_name": "active_power",
                "value": 70
              "0x0508": {
                "attribute_name": "rms_current",
                "value": 505
              "0x0505": {
                "attribute_name": "rms_voltage",
                "value": 239
              "0x0300": {
                "attribute_name": "ac_frequency"
              "0x0401": {
                "attribute_name": "ac_frequency_divisor"
              "0x0302": {
                "attribute_name": "ac_frequency_max"
              "0x0400": {
                "attribute_name": "ac_frequency_multiplier"
              "0x0000": {
                "attribute_name": "measurement_type"
              "0x0403": {
                "attribute_name": "power_divisor"
              "0x0402": {
                "attribute_name": "power_multiplier"
              "0x0507": {
                "attribute_name": "rms_voltage_max"
              "0x0510": {
                "attribute_name": "power_factor"
              "0x050a": {
                "attribute_name": "rms_current_max"
              "0x050d": {
                "attribute_name": "active_power_max"
              "0x050f": {
                "attribute_name": "apparent_power"
        "out_clusters": {}
Is it possible to divide it by 1000?
