Smart Switch for Floodlight camera
I’m looking into getting this Netamo floodlight camera for the front of our house. We don’t have wiring for a doorbell and this seems like the best option to get some security coverage in the front area.
The light fixture is understandably connected to a switch just inside the door. I’m wondering if there is a smart switch i can install that will provide the fixture with constant power, so the camera stays on, but allow me to have a physical switch that I can connect to home assistant, or even google home, to toggle on the light itself on the camera / light.
most switches i see are actually impacting the power feed to the light and it’s been surprisingly hard to distinguish between a smart switch that lives in a light switch socket and controls automations, and a smart light switch that regulates power and can be controlled by an app or HA integration.
I can’t be the only one who has tried to make something like this work. Does anyone have experiance with the Netamo camera or any kind of switch like this? I can imagine there are automations where you flip a switch and a whole sequence of events happens. Hoping someone can point me in the right direction. :slight_smile:
The Inovelli’s have this feature. I think its called “smart bulb mode”. Basically keeps the power connected to the light and you can still act on the switch in automations in HA.
On my floodlight cameras I basically just skip the switch to keep the power always on. I then use home assistant to control the light on all of my backyard floodlights based on the physical state of the switch.
nice! these look pretty awesome. are you able to connect the physical switch to an automation somewhere? so if someone just flips the switch up or down do you use HA or some other method of turning the light on and off?
Yup. You can act on a switch event in an HA automation.
And with the Red versions they include scene’s so you can even act on things like double/triple tap up/down in automation’s.
