Smart Switch (No Neutral Required)
Can you please recommend a smart switch and/or dimmer where the neutral wire is not required? I was ready to use some Shelly relays on this project (for a friend) but there is no neutral in the switch box and no grounds anywhere… suggestions?
BTW: prefer wifi based for now and where there is no HUB required.
Thanks,
R
Some tuya wifi switches/relay (can be flashed with esphome) includes capacitor to be installed on the light fixture.
There’s also shelly 1L (older model) that doesn’t require neutral
Another solution is using this hack to get it working with any switches that requires neutral
Right now I’m leaning toward using Shelly Dimmer 2 since a neutral is not required.
