My goal: Control the living room light from multiple locations.
Hardware I have:
Three 2-gang 2-way toggle switches (in bedrooms)
Terminals: LA, LA1, LA2, LB, LB1, LB2
One 1-gang 2-way toggle switch (in living room)
Terminals: L, L1, L2
Several noname WIFI smart switches from China
Input and output: AC 100–265V
Terminals: L-out, L-in, N-in, N-out, S1, S2
What I did:
Light: L wire to smart switch L-out, N wire to N-out
AC: L wire to smart switch L-in, N wire to N-in
All the wall switches are connected in parallel as following:
1-gang switch: L is connected in parallel to smart switch L-in, L1 is connected in parallel to smart switch S1
2-gang switches: all LA are connected in parallel to smart switch L-in, all LA1 are connected in parallel to smart switch S1
For test benching I wired up all the wall switches, the light bulb, and the smart switch using block terminals, and powered everything through a plug cord.
During testing, I hadn’t checked the polarity in the wall socket beforehand, so it’s possible I plugged the cord in reversed, also I accidentally connected all the L1 and LA1 wires to the N-in terminal. This caused a brief one-second blackout, but I immediately unplugged the unit—there was no visible damage or burning smell. After ‘correcting’ the wiring and connecting it properly(? Still haven’t checked the polaruty in the wall socket) to S1, I turned on the AC. The smart switch immediately blew out, though this time it didn’t trigger a blackout.
I tested each switch individually and they all appear to be functioning correctly. I also noticed that all four switches were in the ON position.
Here’s my question:
Is my wiring diagram even correct, or am I doing something fundamentally wrong or maybe even attempting the impossible? Should I give it another shot with a smart switch that’s the same model I have lying around?
Ps: Unfortunately I can’t upload more than one picture per post
