Most thermostats for central HVAC systems are 24VAC. The 240VAC (line power) thermostats are for things like electric baseboard heaters. Both types are readily available.
The more common problem is that older thermostats were basically a switch, with just two wires from the controller. Smart thermostats need power. If you want a smart WiFi thermostat you generally need a wire from the “C” terminal on your heating system, which supplies the 24VAC to run the thermostat.
Thank you for the response, I currently have digital thermostats with a display, which are pretty new. They have 4 wires going in, so they should be capable.
You don’t mention where you are. I’m in the US, but my understanding was that 24VAC was pretty universal for HVAC systems. All the name brand thermostats; Nest, Ecobee, Honeywell, etc. run on 24VAC.
I have not found AliExpress to be a good source for product information. If the product is a commodity, or a brand that you already know will work, they do have some good deals. But for researching specifications, I’d start elsewhere.
As Tom said you don’t mention where you are. When I click the first link, most of the thermostats that come up are 24v. I’m in the US as well maybe set your country in Aliexpress to USA.
There are a few Tuya thermostats which has an HA integration. Not all Tuya will work though, you’ll have to dig through the forum to see if anyone got a particular model to work.
Otherwise the 3 brands that Tom mentioned are the most common but they all seem to have their hiccups though.
Im in European Union - but HVAC systems are not at all common in our country - we have mostly city central heating in apartment buildings, and wood burning or electric heating in private houses.
