I know this is not a new topic here. But it seems that the smart thermostat market has been developing faster than before in the last few months:
We are renovating our newly purchased house and I am still undecided which protocol my new thermostats should speak.
About my infrastructure:
HA @RPi4 4GB SSD,
Conbee2,
12x Shelly 2.5 (Roller Cover / Light)
8x Shelly 1 (Light)
over 20 Zigbee Bulbs / LED Panels
10 Zigbee Window Sensors
Residential house with two floors, basement and attic.
AVM Fritz WIFI Mesh 2.4 / 5 GHz
A total of 9 radiators will be equipped with new thermostats.
The Wifi is used by both IOT devices and consumer electronics (smartphone, tablet, etc.). So far I have not had any problems with it and do not expect any here.
However, I doubt whether WIFI is the right medium for the radiator thermostats because of the battery consumption.
I have tested the DECT thermostat from AVM, but the transmission time of 15 minutes is unsuitable for reacting quickly to open windows.
I am still undecided whether Zigbee thermostats or even Homematic IP is better for my purposes. I have read about the virtual Homematic CCU in Home Assistant and don’t want to rule that out for me either. So far I don’t have an 868 MHz stick on my Home Assistant.
My selection criteria would be:
Reliability of the solution
Use or problem-free coexistence with my Wifi and Zigbee meshes.
Without cloud constraints (like Tado or Homematic Cloud).
Possibility of manual operation via rotary wheel
Long battery life
Visually appealing
Price under 50 euros per thermostat.
I have just bought two Danfoss Ally Zigbee radiator thermostats and they work very well i think. I don’t know where you live, but in Denmark you can get the for about 50-60 Euro’s. But they are probably cheaper everywhere else.
I live in germany and the price is the same here. 59 Euro + shipping.
I know Danfoss but I was not aware that they gone smart with Zigbee. Thanks for that. I really like the rotation wheel. This is a great help to get acceptance in the family.
Did you use the Danfoss Bridge or do you connect them with a Conbee directly?
I connect them directly to my Conbee II through a deCONZ container. Be aware that the in deCONZ they show up as sensors because deCONZ does not have support for climate sensors (yet). But in HA they show up correctly. It can be a little confusing but everything works as it should.
When i first connected them, the temperature reading was a bit off, but it corrected itself after a couple of days.
I think they release it back in October or something.
Thanks for your advise.
Would you really build up a Zwave ecosystem beside the existing Zigbee mesh?
Beside that, does Trane offer radiator thermostates at all?
No not yet, but it should be pretty simple to add. I have build a (little bit complicated) intelligent heating control in HA. It sets the temp based on if i am home, or i am sleeping or if i am a way. It also have a boost function to quickly get the temperature to my set point in my apartment. And it gives my notifications of its state when i am not home.
If you have a Zigbee network, then choose Zigbee devices and if you have a Z wave network then choose Z waze.
Z wave should in theory be more stable but is also a little bit more complicated when it comes to creating a good network.
This will automatically change the mode between home and night by using the alarm sensor from my phone and/or trigger this automation from other automations.
alias: Skift mellem dag og nat mode
description: ''
value_template: >-
{{ now() | as_timestamp >=
(states('sensor.oneplus_a5000_naeste_alarm')|as_timestamp - 1800 ) }}
- platform: numeric_state
entity_id: sensor.oneplus_nord_sleep_confidence
below: '100'
for: '0:10:00'
condition: []
- choose:
- conditions:
- condition: state
entity_id: person.smon
state: home
- condition: state
entity_id: sun.sun
state: below_horizon
- condition: time
after: '20:00'
before: '04:00'
sequence:
- service: input_select.select_option
option: night
entity_id: input_select.home_mode
- conditions:
- condition: state
state: night
sequence:
option: home
- service: script.thermostat_boost_function
data: {}
default:
option: home
mode: single
Thanks for sharing. Doesn’t look overcomplicated.
Nice idea to take the “sleep_confidence” as condition. I guess that’s a sensor from your mobile as well.
Let’s see what I will take into account for my trigger and conditions. Motion, used devices, usual routines, maybe one could integrate a neural network to learn from our habbits.
But first, I have to get the smart thermostates. Sadly, Danfoss is the only established radiator manufactorer that offers Zigbee devices. And as usual rather expensive.
