Thought I would share this for those of you that may be interested.
I recently bought a new Samsung TV and configured it with my Harmony Hub to launch different sequences based on what I wanted. For example, my sequence to watch Netflix on my TV was:
alias: "Watch Netflix"
sequence:
- service: homeassistant.turn_on
data_template:
entity_id: >
{% if is_state('media_player.samsung_q7_series_65_qn65q7fam', 'on') %}
script.change_netflix
{% elif is_state('media_player.samsung_q7_series_65_qn65q7fam', 'off') %}
script.turnon_netflix
{% endif %}
change_netflix
sequence:
- service: remote.send_command
data_template:
entity_id: remote.living_room
command:
- InputHdmi1
- SmartHub
- DirectionRight
- DirectionRight
- DirectionRight
- Select
device: '52908960'
delay_secs: 2.0
turnon_netflix
sequence:
data_template:
command:
- PowerToggle
- InputHdmi1
- SmartHub
- DirectionRight
- DirectionRight
- DirectionRight
- Select
device: '52908960'
delay_secs: 1.0
data_template:
command:
- PowerToggle
- InputOptical
device: '50675509'
delay_secs: 1.0
There may have been an easier way to set this up but I wanted to determine if the TV was off, turn on all relative devices that I need. Likewise, if the TV was on, I knew all the devices I needed turned on were already on so at that point I just needed to change the Input only.
Here is where my issue came in. When I would launch the Watch Netflix script, there would be an ad after my settings and before my Netflix app. So, instead of my directional rights being 3, it is now 4. This would then launch the ad instead of Netflix. Same for my Prime Video sequence I have set up. VERY frustrating!
I did a little research and came across this site:
I have an ASUS router with the ability to blacklist URLs and set it up just now. I figured this may be able to help others that have come across this or point those of you with different TV models in the right direction.
I will report back once I have had a chance to allow this to run for a little while.
Good Luck!
