We have a smart light installed because we liked the design (hue liane). It’s connected to two traditional switches (up and down the stairs).
It was working like a traditional light as the switches were cutting the power.
Now we’d like to make use of an automation (motion sensor) without replacing the lamp. For that the lamp needs continuous current.
Is there any smart switch we could use as replacement that would provide continuous current while just triggering events so we can connect them on HA. Bonus points for Zigbee protocol.
I’m probably not the only one with that problem but my research was not successful. Does this problem have a name? Also happy to any pointers to other posts.
Zooz calls it “Smart Bulb Mode”. I don’t know if all of their devices have that option but many do. All of mine are currently in a box because I moved into a rental house but I think every Zooz I own has that option.
I normally install friends of hue switches, which can be controlled from the hue bridge or relayed to HA for it to act upon.
The old switches will then either be kept, blocked from being switched or maybe even remove with the wires shorted to always on there after.
What is interesting here is, the sonoff is used for the smart part, decoupled from the relay and he is using a “key switch” to be able to activate the switch anyway in case of minir2 or HA failure or unresponsive.
I bought a minir2 on aliexpress for 8€ including delivery, unfortunately it was defect.
But I’ll do that later for sure even if, sadly, there is no such “key switch” in the brand I’m using at home.
As @WallyR suggested, for the kids, I installed a friends of hue scene switch (green power, no wire nor battery needed) at the side of the existing switch that I lightly blocked (still usable with pressure) and I did 8 different commands with it (short and long press for each of the 4 buttons)
