Greenpower zigbee dimmer from Niko (friends of Hue)
Hello the world,
I’m proud of what I did even if it is still an alpha version of the script.
Ultimately, I’d like to convert it into a blueprint but that will be for later I guess.
I’m using a Niko dimmer switch for Hue system. It is Zigbee switch but no power is required, it is generating the necessary electricity from the movement of the button when pressed.
For this to work, I’ve created 8 template input_boolean like so:
Short press on a button
- binary_sensor:
    state: true
    auto_off: 1
    platform: event
    event_type: hue_event
    event_data:
      device_id: d0909d23bcb033625890ad126fc18d61 # <-- from listening to hue_event
      unique_id: 08b66a92-d988-4abb-adc3-41a4a78b5ea6 # <-- from listening to hue_event
      type: short_release # <-- from listening to hue_event
Long press on a button
- binary_sensor:
    state: true
    auto_off: 1
    platform: event
    event_data:
      type: repeat # <-- from listening to hue_event
And you repeat that for the other 3 buttons, changing the unique_id of the above.
Then, my automation: in theory (1 button, to repeat for the other 3)
alias: Niko dimmer switch
description: ""
  - platform: state
    entity_id:
      - binary_sensor.button1_short_press
    to: "on"
  - platform: state
    entity_id:
      - binary_sensor.button1_long_press
    to: "on"
condition: []
  - if:
      - condition: trigger
    then:
      - if:
          - condition: state
            entity_id: binary_sensor.button1_long_press
            state: "off"
        then:
          - ... (here you put what a short button1 clic should do
  - if:
    then:
      - repeat:
          sequence:
            - ... (here you put what a long button1 clic should do
          until:
            - condition: or
              conditions:
                - condition: state
                  entity_id: binary_sensor.button1_short_press
                  state: "on"
                - condition: state
                  state: "off"
mode: parallel
max: 10
And, practically, here is a full version, (in French, sorry) of my final result:
description: ""
  - platform: state
    entity_id:
    to: "on"
    alias: Bouton 1 court
  - platform: state
    entity_id:
    to: "on"
    alias: Bouton 1 long
  - platform: state
    entity_id:
      - binary_sensor.button2_short_press
    to: "on"
    alias: Bouton 2 court
  - platform: state
    entity_id:
      - binary_sensor.button2_long_press
    to: "on"
    alias: bouton 2 long
  - platform: state
    entity_id:
      - binary_sensor.button3_short_press
    to: "on"
    alias: Bouton 3 court
  - platform: state
    entity_id:
      - binary_sensor.button3_long_press
    to: "on"
    alias: bouton 3 long
  - platform: state
    entity_id:
      - binary_sensor.button4_short_press
    to: "on"
    alias: Bouton 4 court
  - platform: state
    entity_id:
      - binary_sensor.button4_long_press
    to: "on"
    alias: Bouton 4 long
condition: []
  - if:
    then:
      - if:
          - condition: state
            state: "off"
        then:
          - service: light.turn_on
              brightness: 254
              entity_id: light.chambre_enfants
    alias: "Bouton 1 court : Allumer"
  - if:
    then:
      - if:
          - condition: state
            entity_id: binary_sensor.button3_long_press
            state: "off"
        then:
          - service: light.turn_off
            data: {}
    alias: "Bouton 3 court : Eteindre"
  - if:
    then:
      - repeat:
          sequence:
                brightness: >
                  {% set new_brightness =
                  int(state_attr('light.chambre_enfants','brightness'),0) + 5 %}
                  {% if new_brightness >= 250 %}
                     254
                  {% else %}
                    {{ new_brightness }}
                  {% endif %}
            - delay:
                milliseconds: 100
          until:
            - condition: or
              conditions:
                - condition: state
                  state: "on"
                - condition: state
                  state: "off"
    alias: "Bouton 1 long : Luminosité ++"
  - if:
    then:
      - repeat:
          sequence:
            - if:
                - condition: template
                  value_template: >-
                    {{ int(state_attr('light.chambre_enfants','brightness'),0)
                    <= 5 }}
              then:
                  data: {}
              else:
                    brightness: >
                      int(state_attr('light.chambre_enfants','brightness'),0) -
                      5 %} {% if new_brightness < 0 %}
                         0
                      {% else %}
                      {% endif %}
            - delay:
                milliseconds: 100
          until:
            - condition: or
              conditions:
                - condition: state
                  entity_id: binary_sensor.button3_short_press
                  state: "on"
                - condition: state
                  state: "off"
    alias: "Bouton 3 long : Luminosité --"
  - if:
    then:
      - if:
          - and:
              - condition: state
                entity_id: binary_sensor.button2_long_press
                state: "off"
              - condition: state
                state: "on"
        then:
              color_temp_kelvin: >
                {% if state_attr('light.chambre_enfants','color_temp_kelvin') |
                int == 4000 %}
                  2202
                {% elif state_attr('light.chambre_enfants','color_temp_kelvin')
                | int == 2202 %}
                  2702
                | int == 2702 %}
                  3003
                | int == 3003 %}
                  3508
                | int == 3508 %}
                  4000
                {% endif %}
    alias: "Bouton 2 court : Couleur++"
  - if:
    then:
      - if:
          - and:
              - condition: state
                entity_id: binary_sensor.button4_long_press
                state: "off"
              - condition: state
                state: "on"
        then:
                int == 4000 %}
                  3508
                | int == 3508 %}
                  3003
                | int == 3003 %}
                  2702
                | int == 2702 %}
                  2202
                | int == 2202 %}
                  4000
                {% endif %}
    alias: "Bouton 4 court : Couleur--"
  - if:
    then:
      - service: input_boolean.turn_off
        data: {}
          entity_id: input_boolean.sleep_time
      - service: input_boolean.toggle
        data: {}
          entity_id: input_boolean.wakeup_time
      - repeat:
          sequence: []
          until:
            - condition: state
              state: "off"
    alias: "Bouton 2 long : Procédure de réveil"
  - if:
    then:
        data: {}
        data: {}
      - repeat:
          sequence: []
          until:
            - condition: state
              state: "off"
    alias: "Bouton 4 long : Procédure de coucher"
mode: parallel
max: 10
