Smart Water Valve - Tuya Local Setup
I purchased a wifi Tuya compatible smart valve on amazon. I’ve been able to get it to operate using Local Tuya. The problem is, when the switch toggles, there is no indication of on or off. When I push the button the valve operates, but the valve does not return a value stating whether it is in the on or off position.
Has anyone had luck setting one of these up so that it shows the valve position?
Below is what I purchased:
https://www.amazon.com/dp/B09R9QBCTC?psc=1&ref=ppx_yo2ov_dt_b_product_details
You ever get a resolution? Thinking about getting a similar one, and while swapping the chip to an ESP and running ESPHome is possible, it’s honestly more effort than I want to put into it. :slight_smile:
I have a very similar one, I got the localkey but no dps show anything other than -1. How did you manage to integrate it??
