Smart Water Valve, Zigbee
I bought a Smart Water Valve (https://de.aliexpress.com/item/1005005388312078.html) I bought this one because in the review it was told by other buyers that it works with HA.
But after inclusion I don’t have any entities to control it. The only thing I can do is the firmware update. But it is shown as up-to-date.
The device identifies as
TS0601
by _TZE204_a7sghmms
Does somebody have an advice for me?
I’m using ZHA (Zigbee Home Automation). Other devices are working well (also the ‘China’ ones from Ali).
Thanks a lot in advance
While the GiEX works well with the latest Z2M for using this valve with ZHA you may need a quirk to make it work correctly. Take a look HERE for more information about the latter.
See → https://www.home-assistant.io/integrations/zha#how-to-add-support-for-new-and-unsupported-devices
and → Zigbee Guide: How-to setup local custom device handler quirks in ZHA integration
Plus → https://www.home-assistant.io/integrations/zha#knowing-which-devices-are-supported
