Any one have any idea how to flash this device with tasmota and get it to work with Hassio
This was a little more difficult than others but I flashed it with Tasmota.
You need to solder to TX , RX, and GND and 3.3 v and then ground GPIO0. On the esp chip directly since I could not find a pad on the board. I used a grounded needle to touch the pin while powering up.
Can you tell me a little bit more how to flash this device ? I have only flashed sonoff basic switches… What do you mean by "I used a grounded needle to touch the pin while powering up ? "
Sorry for the late reply but “I used a grounded needle to touch the pin while powering up” is
I used a sewing needle and held the ground wire to it and touched the GPIO0 when plugging in the usb serial flasher to put the esp into flash mode since the pin is so small. You only need to hold it there for a few seconds after powering up.
