Hi all,
First post here
I’m currently using the basic thermostat in the climate module to automate my electric radiators to set a target temperature but I was hoping to improve this to prevent such a massive overshoot.
My radiators are quite basic with only a bimetallic thermostat which isn’t accurate so I’m bypassing this by setting it high and relying on HA to switch on and off as required. The problem I have is that these are water filled radiators so take some time to come up to temperature but also then stay hot longer, this means with a large difference between current and target temperature, it can overshoot by a degree or two.
Are there any additional options I can apply, or a better integration, which can essentially “duty cycle” the radiator to get finer control by allowing time for it to release it’s energy before triggering additional heat?
My current config:
climate:
- platform: generic_thermostat
unique_id: climate.thermostat
heater: switch.radiator
target_sensor: sensor.kitchen_temperature
hot_tolerance: 0
cold_tolerance: 0.5
away_temp: 12
sleep_temp: 16
max_temp: 22
Thanks!
